'86 ROW electrical connecters locationn
I'm looking in the '86 wiring diagram, page 6 and there is an 8 pole plug at C55. I'm concerned with wires 1&4 which go between the alarm module and the EZF relay.
on page 7 these wire are a loop?? my question really is, where can I locate that 8 pin loom plug? |
Electrical guru please
Can some clever member tell me what the extra circuitry in the EZF [1986] relay does?
The part no. is 928.615.302.00 and an electrician has replaced it with a '53, which is working at the moment. |
If it's the same relay that's used in my later (1989) S4 with EZK, that "extra circuitry" is a fuse tester. Handy but no need to spend extra for it at replacement time. Use a standard 53b Bosch or equivalent relay and you'll be golden.
By now you are already carrying a cheap DMM in the car anyway... |
Thanks very much DB.
One more grey area brightened up. |
