Power steering pump shaft seal access
1985/6 Euro S2
Had a good look through the list at but can't find any reference as to how to gain access to the power steering pump shaft seal? I have the pump split , shaft must pull off somehow but can't fathom it.
Will try to post pictures later
D
D
The pump is identical to the 944. The only difference is the pulley and pressure relief valve spring.
Here are are a couple references for rebuild. I rebuilt mine a couple years ago and it was a pretty easy straightforward rebuild.
https://www.pelicanparts.com/techart...mp_Rebuild.htm
