WTB: Green top 42lb injectors
Does anyone happen to have a set of the Ford/Bosch 42lb green top injectors laying around they would like to part with? Please let me know. Thanks!
Good luck on that. They're like hens teeth. Every once in a while a "real" set will op up on Ebay, but then they want stupid money for them. If possible I would make adaptors to use the EV6 (?) style, which are WAY more prevalent.
Yeah, that’s what I’m thinking. Thought I would try my luck here first.
Probably in the 500ish range. I’m close now. From Sharktuning I know my 30lb are just about at their limit and I’ve been considering upgrading my current Eaton roots to a 2.3L twin screw. Jim Corenman has been a great help and he had suggested the 42lb green top injectors to be a good fit with what I’m doing.
This forum needs a Like button.
I like the filter set up!
Watch the compression of the tube prior to the MAF. The MAF does not like turbulent airflow entering it. I was hunting down a mild surging for ages before i cam up with an idea that worked perfectly.
then i come to find out that they make a specialized honeycomb material just for the purpose of smoothing turbulent airflow....(im still running my OXO apple slicer!!...)
Wow that a good power level with the Eaton!!! Your setup looks really clean. I like it. Mine is not nearly as clean and tidy. BTW, what kind of filter do you have under there? And is that a belt guard I see over the s/c pulley? I started to make one copying the 03-04 Mustang Cobra but decided it wasn't a priority, so I put it on the back burner.
Thanks for mentioning the airflow issue Tony. I guess I need to address that before I start Sharktuning.
It’s a K&N 5x8.5”, RU 1785 I believe. Quite a bit bigger than what it came with.
Yes, that’s a belt guard. Built that at the same time I built the air box. Probably unnecessary but just another detail. I will probably redo a bunch again when I put the twin screw on. Still a work in progress.
Here is a pic of what it looked like when I got it.
