928 Forum
Sponsored by: 928 Specialists
We've had a 928 fire, and here's what we learned...
Old 02-20-2019, 05:48 PM
Carl Fausett
Developer
Carl Fausett's Avatar
Oh Boy! We know from experience that insulation isn't as abrasion-resistant or flexible (prone to cracking now) than it used to be.
Questions? Tech Support?
Call 920-485-0928
International 001-920-485-0928
Email: [email protected]
Website: https://928motorsports.com/
Instructions: http://www.928motorsports.com/install.php
Carl Fausett is offline
Old 02-20-2019, 05:53 PM
BIMMERMIKE
User
BIMMERMIKE's Avatar
Can you please highlight the area of concern.
I'm glad nobody was hurt and damage to a minimum, could have been much worse!!
Originally Posted by Jason89s4 View Post
Wow. I just checked mine, and the way the positive battery cable is routed at that location it looks "designed" to literally rub up against the edge of that mount for the connector, until it saws through the insulation!
You can even see in the pic where the paint has rubbed off!
BIMMERMIKE is offline
Old 02-20-2019, 05:54 PM
Jason89s4
Disconnected and pulled back the positive cable from the previous post pics.
Sure enough, that light pink area is where the insulation was up against the bracket and it is starting to rub off!
Knowing what I do of the history of my car...my educated guess is that right now is the first time that cable has been disconnected and pulled back like that.
(You now have Exhibits 1,2 and 3 for your insurance.)
Jason89s4 is online now
Old 02-20-2019, 05:57 PM
Ad0911
User
Ad0911's Avatar
Great product! I just put it on my wish list for combined shipping with some other parts.
Ad0911 is offline
Old 02-20-2019, 06:03 PM
Carl Fausett
Developer
I made 20 kits. I just let out PO's to make another 20 right away.
Call 920-485-0928
Old 02-20-2019, 06:05 PM
G8RB8
G8RB8's Avatar
Where is the pic of where you actually blew it without melting the insulation? Isn't that the point?
G8RB8 is online now
Old 02-20-2019, 06:25 PM
rjtw
User
Damn.
rjtw is offline
Old 02-20-2019, 06:30 PM
ROG100
ROG100's Avatar
This is my car and the fire was caused by a power steering hose bursting.
ROG100 is offline
Old 02-20-2019, 06:33 PM
ROG100
ROG100's Avatar
Now to the customer’s 928: we had just finished the work on it that the customer requested, and he was coming the next day to pick it up. I’d taken it for a test drive, all was well, but because it was going to rain, I decided to park it inside for the night.
So if it was just parked for the night why were the fender covers still on it and the car on jack stands - inquiring minds want to know?
ROG100 is offline
Old 02-20-2019, 06:38 PM
ALKada
ALKada's Avatar
Good point. Up on jack stands and fender covers don’t look like “for the night”...
ALKada is offline
Old 02-20-2019, 06:46 PM
islaTurbine
User
islaTurbine's Avatar
NVM. Must have misread the applicable models.
islaTurbine is offline
Old 02-20-2019, 06:58 PM
linderpat
linderpat's Avatar
Another solution would be to insert a piece of thin rubber material behind the cable there, by adhesive to the inner fender, so that regardless of the wire insulation, at the touch point it is insulated.
linderpat is offline
Old 02-20-2019, 07:09 PM
worf928
worf928's Avatar
The big red unfused line at the jump post is - from the factory - looped around the harness and connector so as to avoid touching the mounting plate. Or, in other words, not like the pictures above.
Reason #1 to always route things the way the factory did unless you are 100% sure you know better.
When doing a timing belt on ‘87+ and periodically on any 928, it’s important to inspect these unfused lines for damage to the insulation, proper routing and ‘rub’ protection. Two of these at the jump post, ABS power on the other side, starter and alternator. Routing the ABS power correctly after a timing belt is vital. I’ve ‘saved’ several 928s where the ABS line was 1 harness covering molecule away from shorting due to rubbing on the belt cover side, or being cut by the power steering belt.
So: pay attention to that stuff.
On Carl’s original subject: that sucks, glad it only took the car. Owner’s likely not happy. The master fuse looks interesting.
worf928 is offline
Old 02-20-2019, 07:13 PM
Jason89s4
Linderpat,
Similar thought here. I was thinking put a 1.5 inch piece of silicon heater hose around the cable where it "rubs" up against that bracket.
Once the cover is in place you won't be able to see it.
Old 02-20-2019, 07:26 PM
Red Flash
User
Red Flash's Avatar
Carl, thanks for sharing this experience and the new learnings. Very happy for you that it wasn't worse. I almost completely burned down my new kitchen a few months ago, if it makes your feel any better... This stuff happens.
I know this does not apply to your situation, because the car was in the process of repair and release. For cars however that sit longer periods, I tend to unhook batteries. For the most part, the parasitic drains kill the batteries, and on the other hand, I just don't trust them for months at a time hooked up without being attended to.
Red Flash is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
