928 Forum 1978-1995
Sponsored by: 928 Specialists
S4 Engine into ‘84 - tachometer reads low
Old 02-15-2019, 10:18 PM
Socal_Tom
Socal_Tom's Avatar
Default S4 Engine into ‘84 - tachometer reads low
Gentlemen, hope all is well, I’ve been distracted with some air cooled stuff but have been picking at the 1984 again.
I had a chat with the shop that Rob Edwards recommended and it appears that my lazy tachometer is a problem because they do the emission tests at set RPMs.
My car is still running the original instrument panel and it appears that having to ECUs is confusing it as it reads low by at least 50%.
Do I need some sort of signal doubler to resolve this? Would switching in a later instrument cluster be a better/worse idea?
Any clever ideas?
Thanks!
Old 02-16-2019, 01:46 AM
daveo90s4
daveo90s4's Avatar
Default “Tach-adapt”
google the term “tach-adapt” -did everything required for my 4 cyl to 6 cyl engine swap on my 914 and keeping original tachometer cheers. DaveO
Old 02-16-2019, 07:25 AM
danglerb
danglerb's Avatar
Its the two distributors vs one, it looks like two 4 cylinder engines to the tach. Might be something on the instrument panel like a jumper etc, but I don't know.
Old 02-16-2019, 09:07 PM
Socal_Tom
Socal_Tom's Avatar
Thanks gentlemen, what I suspected and I will do some searching on the product .
Quick Reply: S4 Engine into ‘84 - tachometer reads low
