928 Forum 1978-1995
Sponsored by: 928 Specialists
Flat Plane Crank
Old 02-02-2019, 04:18 PM
UKKid35
UKKid35's Avatar
Default Flat Plane Crank
Insane costs aside, would it be possible to fit a flat plane crank to a 928
I presume the current cams would still work
Would it shake itself to pieces?
I seem to remember some Ferrari engines existed in both cross plane and flat plane versions, or am I mistaken?
Old 02-02-2019, 04:37 PM
Bigfoot928
Bigfoot928's Avatar
change the crank, change the cams.
Old 02-02-2019, 04:55 PM
UKKid35
UKKid35's Avatar
If there is anyone who knows about insane costs...
Thanks SG, I get it now, piston movement would be totally different on each bank, not just relative to the other bank
Old 02-02-2019, 05:47 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
944 cams? It's the flat-plane-crank half-a-928 engine. Seems like they should work, ASSuming the torsional vibration of two didn't shatter the crank.
Old 02-02-2019, 06:01 PM
UKKid35
UKKid35's Avatar
They have balance shafts don't they?
Old 02-02-2019, 06:41 PM
Wisconsin Joe
Wisconsin Joe's Avatar
Yes, 944 engines have balance shafts.
Old 02-02-2019, 06:49 PM
SwayBar
SwayBar's Avatar
Do a search on the Ford GT350 Voodoo engine development - a flat-plane-crank engine. It took Ford with all its resources and expertise, quite a bit of development time to get it right.
With that said, it would be much easier and cheaper to buy the Voodoo with its computers and harnesses, than to attempt what you propose with the 928 engine.
Not only that, the Voodoo is completely debugged.
Old 02-02-2019, 06:54 PM
Wisconsin Joe
I thought this had been brought up before.
I don't have the engineering background to fully understand all the issues, but many are covered in this thread:
https://rennlist.com/forums/928-foru...28-engine.html
Old 02-02-2019, 06:57 PM
UKKid35
UKKid35's Avatar
Definitely not proposing - just idle pondering, having spent all day working on my AJP8
Old 02-02-2019, 08:22 PM
C531XHO
C531XHO's Avatar
Just whip one out of a lotus v8. Comes with twin turbos apparently. See Top Gear Patagonia special...
Old 02-02-2019, 09:21 PM
jpitman2
jpitman2's Avatar
ALL Ferrari V8s are flat plane, except one model made for Lancia. At least up to around 2000. They dont seem to have a bad name for vibration AFAIK. Just put a 2 plane forged crank in a press, flatten it, heat treat, good to go. Chevy have sold flat plane cranks for years, last I looked.
jp 83 Euro S AT 57k
Old 02-03-2019, 06:17 AM
UKKid35
UKKid35's Avatar
Great thread - thanks
Old 02-03-2019, 07:19 AM
928 GT R
928 GT R's Avatar
Received 4,950 Likes on 1,913 Posts
Spot on!
Not sure how many of you have heard one in action, but the Voodoo engine sound is amazing! Flat plane cranks are also part of the reason that Ferraris engine sound is so intoxicating!
Add full throttle to the V12 flat plane configuration and it seems that the sky is tearing open!
Old 02-03-2019, 10:00 AM
SwayBar
SwayBar's Avatar
Did you really?
Please show just one example.
Old 02-03-2019, 12:50 PM
V2Rocket
Rainman
V2Rocket's Avatar
jp 83 Euro S AT 57k
flat-plane V8 has the same imbalance as straight-4 in that the rod/piston accelerates at a different rate at BDC vs TDC so the crank is a big torsion bar...
as with I-4 it can't be cured but can be managed by keeping rod/piston mass low and using longer rods....or using balance shafts.
the biggest F-V8 is what, 4.5L, with baby 94mm pistons that you just know are micromanaged into minimum weight spec.
Quick Reply: Flat Plane Crank
