928 Forum 1978-1995
Sponsored by: 928 Specialists
ITB setup startup - removed idle stabilizer - ok?
Old 01-12-2019, 09:35 AM
Gulpilen
Gulpilen's Avatar
Default ITB setup startup - removed idle stabilizer - ok?
Hi all, I am ready with my car with ITB for startup and tuning (Shark tuner). My question, I removed the idle stabilizer valve and is there anythong I need to do with the wire that now is not connected to idle stabilizer valve anymore?
Thanks,
Jonas
Old 01-12-2019, 09:56 AM
SwayBar
SwayBar's Avatar
Not sure about your question, but more details and pictures of your setup would be greatly appreciated.
Old 01-12-2019, 10:39 AM
Gulpilen
Gulpilen's Avatar
Old 01-12-2019, 02:41 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
No harm on leaving the connector disconnected, maybe putting a protective sleeve/cap over it and secure it out of the way. I'm curious how you plan to manage idle speed beyond the stop screws on the individual TB's.
Old 01-12-2019, 02:56 PM
V2Rocket
Rainman
V2Rocket's Avatar
gonna need sound of this beast too...
Old 01-12-2019, 02:58 PM
Bigfoot928
Bigfoot928's Avatar
at w
I have no idea how he is going to do that with the factory computers. Aftermarket stuff usually has enough stuff to dial it in to idle, and worst case would be to plumb the ICV in and you can feed vacuum tubes to each ITB.
I'm not planning on using an ICV with mine either.
Old 01-12-2019, 03:33 PM
Gulpilen
Gulpilen's Avatar
Thank you, I will put plastic around it. Idle, let us see whats needed 😊! If the idle is too low when cold and too high when warm I will do like suggestion ”hoses after ITBs and before ITBs another hose -connected to original ICV”. The sound, I will let you know!
/Jonas
Old 01-12-2019, 07:11 PM
drnick
drnick's Avatar
Jonas, I’ve recently been through a similar process although my tuning was for the JDS alpha n. Are you using forced induction?
The static setup is important and can save you time further downstream.. Balancing the throttle plates and getting them to open in sync, setting correct fuel pressure.
As for idle, hopefully others can help. I’ve got the stock ICV feeding vacuum passages through all eight itbs. The JDS idle controller works effectively with this.
Old 01-13-2019, 09:01 AM
Gulpilen
Gulpilen's Avatar
Not forcera in this setup. My FP is under control with fpr (aftermarket).Yes, thanks for your heads-up, it has been a small worry of having them itbs open exactly the same.
My Idea with the throttle plates is to (not yet tested...) using a vacuum measure by one ITB and adjust the rest with the same. Using a clock, in my setup, seems to be not so easy. Not for me anyway...
Ok, a T connector to vacuum hoses from stock ICV. That sounds good! Will look at JDS idle controller!
Old 01-13-2019, 06:41 PM
drnick
drnick's Avatar
Jonas, very crudely I used a micrometer slid down the itb mouth to measure the throttle plate deflection for initial setup. If the car is not street driven then you may be ok without an ICV? Just set the throttle plates for a fast idle and call it good? I’m not sure what others have done..
My setup courtesy of Alex P uses bmw itbs with the vacuum passages cast in place.
Old 01-13-2019, 06:43 PM
andy-gts
andy-gts's Avatar
Does the hood close without any alteration, and there certainly are a lot of hoses,,,,,,,,,,,NOS or OIL CONTROL or methanol injection ??
Old 01-14-2019, 10:32 AM
Strosek Ultra
Strosek Ultra's Avatar
There are very many multi-cylinder engines having no ICV out there so why should it not work? The throttle plates have to be synchronized. Set the throttles for good idle when engine has reached operating temperature. The only problem I can see is the idle rpm cold will probably not be the same as when engine is warmed up. Here is how they do it for a bike.
Åke
https://pastframe.wordpress.com/2014...nchronization/
Some additional info.
http://www.compsystems.com.au/index....whole-ls-range
Old 01-14-2019, 06:46 PM
Ducman82
Ducman82's Avatar
And where will you get the vacuum for the brake booster? I'd plumb in an IAC. Makes life sooo much easier. Not to mention a standalone computer
Old 01-14-2019, 07:00 PM
karl ruiter
karl ruiter's Avatar
Having tried to tune a V12 in which the idle speed was controlled by the setting of the 12 throttle plates, I suggest you may end up wanting the ISV. I have found maintaining the sync over time and temp difficult.
Old 01-14-2019, 08:02 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Curious, can you fab a manifold or block and distribute air from the ISV equally to all 8 ports after the butterflies as long as there is a 'vacuum' port per each runner?
Quick Reply: ITB setup startup - removed idle stabilizer - ok?
