Fuel pump pressure vs flow
#32
Hi Allan, probably the stuck piston will be my pressure issue.
I am checking how to remove it safely
As for the seals, the ones needed for my primary pressure regulator (F 026 T03 010) will be, according to my FD 0438 100027 :
lower Oring = 2 430 210 036
larger Oring = 2 430 210 051
#34
Great news Gerrit !
For the other O ring , it's to be sure you have the good size .
Your fuel flow is ok , the pressure is good , now you just need to adjust the CO and idle .
Back to the road !!!
I received today your box with the bottles and parts !
Thank you !
Thank you !
#41
If there is anything I can do to help you with something , please let me know.
Gerrit
