928 Forum 1978-1995
Sponsored by: 928 Specialists
Latest guidance on LED headlights
Old 01-01-2019, 11:50 PM
drscottsmith
drscottsmith's Avatar
Default Latest guidance on LED headlights
All -
Been searching but but cannot fund the latest in the discussion. Also realize the technology changes rather frequently.
As of today, what is the best LED headlight bulb for our cars?
I have an 83 928s, but the sealed beams have been replaced with 8” H4 euro units.
thanks
-Scott
Old 01-02-2019, 02:05 AM
rjtw
rjtw's Avatar
Start here: https://rennlist.com/forums/928-foru...l#post15514412
Also contact Ed Scherer for a pair of sealing caps for the H4 assembly.
Old 01-02-2019, 10:09 AM
Chris Lockhart
Chris Lockhart's Avatar
Originally Posted by drscottsmith
All -
thanks
-Scott
I'm jealous!! I had no idea that you had euro H4's. You get better choices. Good luck!
Old 01-02-2019, 01:16 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Here's...something at least interesting,..
https://www.boslla.com/
Old 01-02-2019, 03:16 PM
NewToPig
NewToPig's Avatar
I've tried to do this dual color before to keep the vintage warm look but it's always so hard to recreate. The bulbs look promising BUT we'd have to run another circuit to cycle the lights to change the colors. It would be super annoying to put the motors up/down several times to get the setting you want.
Old 01-02-2019, 03:29 PM
Speedtoys
Speedtoys's Avatar
Is turning them off/on via the switch an issue here?
The motors dont have to move to turn the bulbs off.
Old 01-02-2019, 03:34 PM
NewToPig
NewToPig's Avatar
Yes, to cycle the mode is turning the bulb on and off. How to I cycle with the heads up?
Old 01-02-2019, 03:41 PM
Speedtoys
Speedtoys's Avatar
The switch has two positions.
You dont have to fully cycle the switch to turn OFF the headlights.
Turn it back one, and the lights go off, but stay up.
Old 01-02-2019, 03:51 PM
Ed Scherer
Ed Scherer's Avatar
It might be worth looking back at a review I did (back in July 2017) of a few LED H4 options. Pay particular attention to geometry and the resulting beam patterns.
I haven't seen anything since that time that looks much, if at all, better than the model (which shows up under various brands, sometimes with minor cosmetic differences) I recommended in that post.
Old 01-02-2019, 05:05 PM
NewToPig
NewToPig's Avatar
Thanks and good write up. I ordered the Boslla lamps and will report back what the pattern is like.
Old 01-17-2019, 01:17 AM
Speedtoys
Speedtoys's Avatar
Got mine from the kickstarter batch.
www.flickr.com/gp/28804666@N08/225PAD
Im guessing that the LED placement is _just a tad_ long or short from the LumiLEDs I had in there that had a broader "spray" pattern up and to the right...But these align crisp on the proper line to keep out of peoples eyes.
Im happy.
Old 01-17-2019, 10:36 AM
drscottsmith
Ed that was really my question - had technology improved any for our 8" H4 setups since you did the original research. Thanks to all for chiming in as well. Always good to have opinions for people to consider in the future as someone else comes along with the same question.
Thanks!
Old 01-17-2019, 11:39 AM
Ed Scherer
Ed Scherer's Avatar
Based on just looking at the pictures of the Boslla H4, it might be a well-designed unit. The geometry (LED placement), presence of a shield for the low beam, and LEDs on both sides of each bulb is a good sign.
It also looks like the current sealing caps I've got probably wouldn't work on these. It would be good if somebody who gets a Boslla H4 set takes and posts some measurements (most importantly, the diameter and length of the cylinder between the flange and the heat sink).
I haven't been able to find specs on the Boslla H4 bulbs, so there's not much to go on other than the pictures.
Old 01-19-2019, 07:34 PM
Speedtoys
Speedtoys's Avatar
Here's what I think you wanted and more.
Old 01-19-2019, 07:40 PM
Speedtoys
Speedtoys's Avatar
If no photos. I'm on the app.
Try this Ed
https://www.flickr.com/gp/28804666@N08/758w59
Quick Reply: Latest guidance on LED headlights
