928 Forum 1978-1995
Sponsored by: 928 Specialists
32 Valve camshaft options
Old 01-01-2019, 10:13 PM
Louie928
Louie928's Avatar
Originally Posted by 928sg
I guess I should have stated that I already have a set of Simard gun drilled cams. Since he isn't making them any more I can add the specs to the list
Intake:
Lift .450 Duration 226 @ .50
Exhaust:
Lift .420 Duration 220 @ .50
The LCA (Not LSA) is 110
These were designed by Mike Simard in conjunction With Harvey Crane of Crane Cams before his passing. Mike has since dropped from the 928 scene and I know that he made at least 5 sets of blanks of the gun drilled billet cams, but I don't know how many sets actually found homes in 928 engines.
Hi Sterling,
I thought you had a set of Mike's cams.
Louie
Louie928 is offline
Old 01-02-2019, 11:20 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Originally Posted by Louie928
I'd suggest one of Colin's offerings depending on the ultimate use you intend for the car. You'll have a bucket of low/midrange torque so work on enhancing to top end. Your ITBs will help take care of that. The Ford 4.6 DOHC valve springs will work fine. They are of the "beehive" design. Tuomo has a lot of data on those.
Louie, do you have a supplier and part number for these springs?
Kevin in Atlanta is offline
Old 01-18-2019, 11:32 AM
Strosek Ultra
Strosek Ultra's Avatar
Originally Posted by SwayBar
Ake, did you ever install and get this huge cam up and running?
And being so big, wouldn't it require ITB's?
The hot street cams #278/274 are made and are going into the next iteration of the twin turbo terrorizing the street engine.
The full race cams #136/206 are also made and are going into my 7L stroker engine project. It is motorcycle profiles used for drag racing back in the 70´s and 80´s. The long duration cams will certainly add much power in the upper range but the low up to the mid range torque will suffer. I expect the 40% cubic increase and the possibility to adjust the cam timing and overlap will make the engine driveable in traffic. This is an experiment, if it does not turn out good I will put in some cams having shorter duration. The cams will not work well unless ITBs and tuned headers are used. The heads will be fully ported having 42/36 mm valves
https://rennlist.com/forums/928-foru...ughout-15.html (start reading at post # 218). Shaftless 55mm ITBs made by ATPower in England will be used.
Åke
Strosek Ultra is offline
Old 01-19-2019, 01:40 PM
SwayBar
SwayBar's Avatar
Ake:
SwayBar is offline
Old 12-26-2019, 12:06 PM
928NOOBIE
928NOOBIE's Avatar
My understanding is we have technology to make changes to lift/duration on existing camshafts...I'm thinking of increasing the duration of my '86 cams to match the GT etc. Does anyone have experience using these services and could make recommendation / give me an idea of costs?
This is something that would be done while replacing cam chains/pads/lifters type of job....any input appreciated..thanks.
928NOOBIE is offline
Old 12-26-2019, 12:10 PM
SwayBar
SwayBar's Avatar
The S3 and GT cams are essentially the same except for lobe separation, so no need for modifications.
SwayBar is offline
Old 12-27-2019, 12:47 AM
Bigfoot928
Bigfoot928's Avatar
Bigfoot928 is offline
Old 12-27-2019, 06:54 AM
ptuomov
ptuomov's Avatar
So here is a question. Why do the GT cams suffer from pitting on the lobes and the S3 cams don't?
One could speculate that it’s possibly the valve springs being slightly different and set up differently. Longer springs set up further from coil bind may be better in this case, as the S4 cams don’t look bad.
Another reason may be that the lifters are different. There are at least two kinds lifters out there in factory original cars.
Later cars may have been run more often with unsuitable oil.
Small sample problem, how many GT cams have you seen?
The adverse selection effect might be driving the loose good GT cams out of the market?
Finally, the later (better) cars may simply have been run more miles on average.
ptuomov is offline
Old 12-27-2019, 10:47 AM
SwayBar
SwayBar's Avatar
As a data point only, I have two sets of GT cams with zero pitting, and one of those sets have been at the track extensively.
I have one set of S3 cams with pitting.
SwayBar is offline
Quick Reply: 32 Valve camshaft options
