need more bass
No. Not really. Oh you *can* pump-up the volume in that low mid-range (not mid-bass folks. bass stops at about 250hz) but it mostly just makes the surrounding bands too loud.
Seriously: if you have something sitting in front of a speaker, EQ settings aren’t your issue.
In the typical 928 seating arrangement, the driver’s ears do not have a clear path to the 6” drivers in the C pillar.
I've seen some installs with a larger driver in the lower part of the door, which would help this a lot, I would think (although shouldn't the larger stock position door drivers be able to handle 250-2K pretty easily?) but that was more irreversible modifications than I was willing to make at the time. Is that area deep enough to fit something with decent mid-bass/low mid range?
I guess you hit the nail on the head,,,,,,I am needing more mid bass.......I have played with the amp and am getting better sound....I will go back to the stereo installer and talk a little more , I dont mind another amp and some more subtle speakers.... thanks
Received 1,542 Likes
While I have spent considerable time fixing the interior wiring I've not had to go into the doors, so I don't know what was done to accommodate the speakers. If I recall correctly the 1/2" trim rings that came with the MBQ kit were used. I would think though, that the drivers must be super shallow. Overall the system has pretty 'even' sound. It fills in the 'notch' in the 300-500 Hz range and adds some richness in the ~200 Hz range. The door ends up being more-or-less a ported enclosure.
