928 Forum
Sponsored by: 928 Specialists
Missing A/C electric air valve - 1978 OB
Old 12-13-2018, 03:55 PM
islaTurbine
User
islaTurbine's Avatar
Default Missing A/C electric air valve - 1978 OB
I hope this isnít too n00b of a question around here, but searching on here and Google didnít turn up anything for me.
My my car is dropping about 200 rpm during idle whenever the AC compressor kicks on. The idle is currently a bit high so itís not a big problem, but it might become one if I end up adjusting it down to an idle rpm of around ~800 rpms.
Upon further inspection, it looks like the A/C bleed air valve (part number 928-606-215-01) is missing along with all of the associated tubing and wiring that would connect to it. I suspect that this might be whatís causing the idle rpms to not be compensated when the compressor turns on.
Is there a mod out there that would entail removing these components? Im still a bit new around here so there might be a common modification that has this removed. Also, am I on the right track in thinking that having this valve missing will negatively affect idle rpms with the air conditioning on?
The car is a 78 with the 5 speed.
Thanks folks.
islaTurbine is offline
Old 12-13-2018, 04:30 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
What's the last 4 digits of your VIN? The early '78s didn't have an aux air valve, not sure when the changeover occurred. #1117 has it, #107 does not.
Rob Edwards is offline
Old 12-13-2018, 05:02 PM
islaTurbine
User
Mine is a Jan. 78 build. #0338. That would explain it!
So if thatís the case, then do these early OBs simply require a higher warm idle to compensate for the AC compressor compared to later 928s?
Old 12-13-2018, 06:20 PM
SeanR
Running up the Odo'
SeanR's Avatar
Chuck Schreibers early '79 doesn't have it either.
SeanR is offline
Old 12-13-2018, 10:38 PM
vze2jshn
vze2jshn's Avatar
Neither does my '78 #342 have the AC auxiliary air valve.
vze2jshn is offline
Old 12-13-2018, 10:41 PM
islaTurbine
User
Out of curiosity, what is your warm idle rpms with and without the A/C compressor running?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
