Accelerator cable spring??
have tried to get some info on this spring in another thread about the pedal with no luck; thought I would try a different approach.
https://cimg1.ibsrv.net/gimg/rennlis...279ff861a8.jpg matt968 explained in the other thread, that this spring is compressed when the accelerator pedal presses down on the kick down switch on auto cars. but, what is the function of this spring on 5 speed cars? and why would this spring ever compress, since it is part of the outer sheathing? I would assume that the spring will only compress if the inner cable is beyond its limit, and then causes the outer cable to buckle? there is only one part number, for the cable, so no difference between auto and manual cars. maybe this spring has no purpose on manual cars? |
Additional compensation to overcome the despair of having to drive a sh**box manual.
^^^^^Roger, let us all know what stand up club you're performing at this weekend. lol
Isn't the spring present on the autotragic's "accelerator" cable as well?
Total WAG- the spring damps engine vibration being transmitted to the gas pedal (?) |
Educated speculation:
The spring is there so that the cable can be adjusted tight to give a firm full throttle opening with pedal down. Without the spring, the possible excess travel at the pedal would be stretching cable cores and bending or otherwise damaging cables, pivots, rollers, or throttle arms. Consider it a "safety feature" to protect the cable and linkage from excess travel. |
^^^^^dr bob, that reply is the most plausible yet! thanks. I can't see how that spring has anything to do
with the inner cable, or anything to do with the cable adjustment anyone else care to take a stab at this?? |
It's still just speculation.
For those who have some Porsche air-cooled experience especially with carburetor cars, you know that there is a lot of variance in how the throttle is set up WRT getting the throttles all the way open at full pedal position. Many cars have throttles that don't open all the way at full pedal position, while others offer an opportunity to stretch the cable and/or bend linkage when things are set too tight. Getting the adjustment "just right" can take two people if you don't have a mechanical pedal-pusher. My guess is that the spring on the 928 cable casing is there to solve the issues exposed in the older cars. |
Originally Posted by dr bob
(Post 15495288)
The spring is there so that the cable can be adjusted tight to give a firm full throttle opening with pedal down. Without the spring, the possible excess travel at the pedal would be stretching cable cores and bending or otherwise damaging cables, pivots, rollers, or throttle arms. Consider it a "safety feature" to protect the cable and linkage from excess travel. Don’t take my word for it: Take Doc Brown’s. |
thanks dave
