Benno's Intake Refresh Adventures
#91
The CPS sensor is not a hall style sensor. It is a VR (variable reluctance) sensor. Very different operation and it is a wear item.
If you have good power to the EZK and get no spark during cranking (check at the coil leads to minimize items in the middle), then you have a bad CPS sensor.
#92
Running again
Based on the tests above. I swapped out the new CPS with another new CPS and the car started right up. It was raining cats and dogs outside so I wasn’t able to do any real road tests but all the garage tests worked out. I ran it for about 20 min and started it several times.
I want to thank @DrBob for his recommendation to work through the factory test sequence. It really helped take the guesswork out of the problem.
#93
Shakedown complete!
Intake refresh complete, runs and dives perfectly!
Wheels rebuilt! No more creaking!
No play in shifter or clutch - Rebuilt clutch MC rebuilt, New clutch for pivot, replaced rear shift coupler bushings.
https://benno928.wordpress.com/2019/...shift-bushing/
#95
Awesome work. It is so easy to just throw your hands up and that's how cars end up sitting for 10+ years.
I have a new CPS I can test to hopefully avoid this kind of problem.
#97
@Michael Benno How are the coatings on your magnesium alloy parts holding up after these few years?
I was so pleased with the results that I decided to do it again on my GTS
Just be aware, not all ceramic coatings are created equal. Cerrakote is just a coating like paint. It does not have any performance characteristics. The coating used here was a breathable coating formulated for magnesium alloy such that it allows the magnesium to off-gas oil vapor (ie: blocks, wheels, and manifoldly parts). Find a performance ceramic coater that does exhausts, they will likely be able to help formulate something for your needs.
RennHarry (12-14-2023)
