928 Forum 1978-1995
Sponsored by: 928 Specialists
Direction Indicator
Old 01-28-2004, 04:07 AM
Edwill
Edwill's Avatar
Default Direction Indicator
Hi!
I recently heard a snap noise while driving, and only realized that it had something to do with my direction indicator after it didn't switch off by itsself. My turn signals are working perfectly, but I have to manually swith them off now (ie. it odesn't by itsself after turning).
Is there something I can "Super Glue" together?
Old 01-28-2004, 02:10 PM
T_MaX
T_MaX's Avatar
NO!
Old 01-28-2004, 02:34 PM
Lizard928
Lizard928's Avatar
nice looks like the release spring broke time to replace that entire switch assembly
Old 01-28-2004, 02:55 PM
JE928Sx4.
JE928Sx4.'s Avatar
Default Re: Direction Indicator
I've got an extra if you want it. $20.00. Works fine. Markings are a bit worn.
Reminds me. Does Jager make replacement stickers for the turn signal assemply yet? I like the ones they did for the console buttons.
Originally posted by Edwill
Hi!
Old 01-29-2004, 02:36 AM
Edwill
Edwill's Avatar
Thanks JE928, but I live in South Africa, so postage would be more than that :-) Just wanted to know about a quick fix in case there were any...
Old 04-17-2018, 10:04 AM
UKKid35
UKKid35's Avatar
Is there a fix for this?
Perhaps the broken part is a 3D printing candidate?
Old 04-17-2018, 11:20 AM
polecat702
Vegas, Baby!
polecat702's Avatar
What year is you're car? The 89 is year specific, because of the digital/analog dash.
Old 04-17-2018, 02:14 PM
DR
Rennlist Sponsor
DR's Avatar
Sounds like the "tab" broke off of back of the "Steering Wheel Contact/Slip Ring. Part Number 928.347.099.00
Simple install, remove steering wheel, then remove a couple of screws and replace with the new one.
You can pull the steering wheel real quick to confirm. See pic below to see tab that most likely broke off.
Hope that helps,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 04-17-2018, 02:37 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
Nice an old thread from 2004.
the part that breaks off is inside the TS housing .
its a small white piece of plastic held in position with a spring,
it toggles back and forth as the horn ring finger passes it.
The internal parts of the switch wear out over time.
someone here has taken the switch apart and fixed it with parts from another broken switch.
At this point it would be a good idea to buy a good used switch or buy a new part.
Quick Reply: Direction Indicator
