19" Wheels that work well on a GTS? (correct offsets)
I'm still trying to figure out if its the left side thats twisted backward or the right side? Or is the the left front/right rear or right front left rear based on primary load being braking verses drive thrust?
Administrator - "Tyson"
Just because people do things it does not make them right.
Never saw a space shuttle blow up until January 1986- but sadly it did because someone made some invalid assumptions.
One can assume something and be perfectly correct but on the other hand, knowing for sure that something is correct is a different matter altogether. It would be interesting to know how much different the stresses generated within a wheel are when rear mounted and front mounted on the same vehicle. I would think there will be plenty of margin in the design but for sure I do not know that.
I have no idea what the conditions which lead to the Challenger explosion and the frozen o-rings has to do with wheels.
928's came with square wheels configurations until 1987. Same wheel. No amount of anecdotal evidence is going to convince me that in 1987 Porsche designed a wider wheel based on the same casting and it's weaker than the previously made front. If that were the case, you know darn well Porsche would have released a tech bulletin about it.
Case in point: The Porsche classic division is currently racing a 928 with S4 rear wheels on the front. There is a thread on it.
I wish when the owner of my 79 back in the 90's took 8 phone dials and made a set of wider ones, started with '86 951 versions for the rear to get that deep lip. I might still make another set.
That's the #1 thing I hate about the 928 suspension geometry, no easy way to run a fat lip front wheel.
My 928 will have a 1" lip in the front and a 4" lip in the rear!!
"^^Sincere apologies to owners of 19 inch rims- cannot stand the sight of them on a 928- they just do not look right IMHO"
There was a beautiful red GTS at the 2012 OCIC running 19's that looked great. IIRC you could have special ordered these in correct offsets for the 928. If you like these wheels^^check with Kevin/Hold On. He pulled the same type wheels off his 928 and swapped in diff wheels...they may be for sale? (sorry..do not know Kev's offsets) T
For sale are these 19" wheels and tires off of a 2007 9114S. Spacers and extra lug nuts are part of the sale. Will sell with or with out tires. Rims are in excellent condition. Tires have just under 15k miles on them. All for $1,900.00 plus shipping.
Claws are always a favorite! Also, I'm really liking these BBS Carrera Sport wheels. Both are for the Boxster/Cayman gen 2 and I really like the way the rear wheels fill out the fender.
Carrera Sport (BBS)
Front 8.5x19" ET55 PN: 997.362.156.55 (10.6 kg)
Rear 10x19" ET43 PN: 997.362.160.50 (12.4 kg)
Carrera Sport (BBS)
Hey Fred^^Must of been Kevin's (Hold On) that had the 19's. Kev's car below at the 2012 OCIC in Kansas. IIRC Kev removed 19's wheels because of trammeling but boy they sure did look good on his car.
https://rennlist.com/forums/928-foru...and-tires.html
