My New 1983 928S, sat for 14 years
#76
They are the color coded connectors on the bottom of the CE panel. They are lettered A-X left to right but Y & Z are between N & O.
E7 would be the fifth plug from left and pin 7 is circled.
#77
Thank you for the clarification.
I started the diagnosis and from the CE, E connector is from the 6th slot. the 5th slot is empty no connector.
Also, there is no power from E7. E7 is a black and red wire.
#78
F7 is a black and red wire connecting brake switch to the lamp control.
#79
There should be labels below the plugs on the board showing what they're supposed to be. The connector you're looking at is F not E, and it does appear that E is missing. I don't see where it could be. I'm surprised nobody caught that before now
#80
Thanks to bwarren97 and Majestic Moose.
Oh dear... Just found it. It was removed and left behind the CE board. Now I can start going over the diagnosis. Will update about my progress.
