Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Reload this Page >
Oil filler and crankcase ventilation baffle for supercharger application
928 Forum
Sponsored by: 928 Specialists
Old 12-09-2018, 12:23 PM
  #46
worf928
worf928's Avatar
Why don’t you (didn’t you) drill a small divot in the baffle to make room for the OE part?
worf928 is offline
Old 12-09-2018, 01:27 PM
  #47
Michael Benno
Michael Benno's Avatar
Originally Posted by worf928 View Post
Why donĺt you (didnĺt you) drill a small divot in the baffle to make room for the OE part?
That would have been a decent idea too. However I wasn't sure how thin the aluminum is at the interference point and I didn't want to create an non-anodized area from drilling and frankly I don't have good tooling to hold the baffle and drill into a 45-degree bevel. I figured modifying the plastic was the easiest and cleanest for me.
Michael Benno is offline
Old 12-09-2018, 02:28 PM
  #48
worf928
worf928's Avatar
Originally Posted by Michael Benno View Post
That would have been a decent idea too. However I wasn't sure how thin the aluminum is at the interference point ... and frankly I don't have good tooling to hold the baffle and drill into a 45-degree bevel. I figured modifying the plastic was the easiest and cleanest for me.
Ah. It wasn't obvious that the plastic weld bump wasn't on the flat part of the insert.
That part would be so-bathed in oil that it wouldn't matter.
worf928 is offline
Old 12-10-2018, 12:15 PM
  #49
hans14914
hans14914's Avatar
Hey guys. Sorry I am late to the party, was at the PRI show.
Yes, a small modification is required to the 87-95 cars in that filing down the driver side plastic weld "bump" on the original filler is required. Drilling a clearance hole on the aluminum part would go through the chamfer, so it was not a very good option. I wanted to make sure there was enough clearance between the wall of the block chimney and the side outlet of the baffle, so that was a small compromise. The modification is quick with a razor, grinder... etc, and will have no effect on the integrity of the plastic filler. The earlier cars with the metal stamped baffles require no modification.
I included o-rings so no goop/sealant is required. They are a full size o-ring, just curl up to look like a lot of smaller o-rings in the baggie. They are a bit of a pain to fit the first time, and may require a bit of stretching, but as soon as they sit in the groove completely, they quickly retain memory and stay in place quite nicely.
I did not use the factory o-ring groove shape, because they cost almost $10 now, and who knows how much in the future (or they could go NLA). These are commonly available for around $1.50
Any other questions, just let me know. I will be around all week.
Hans
hans14914 is offline
Old 12-10-2018, 02:47 PM
  #50
Michael Benno
FYI Coating the O-ring with oil helped with holding it into the groove while mounting the baffle on the block.
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
