928 Forum 1978-1995
Sponsored by: 928 Specialists
Help identifying a screw please!
Old 10-07-2018, 11:42 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,549 Likes on 1,233 Posts
Sure, here you go:
https://webfiles.uci.edu/redwards/pu...202-21-12.xlsx
Old 10-08-2018, 03:24 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,451 Likes on 1,459 Posts
Originally Posted by Rob Edwards
Some of us need spreadsheets, some of us don't. Amateur, pro.
EDIT: Wait, you're calling rear crossmember e-brake bolt because no captive washer. I see what you've done there......
Manual cars need a 50mm bolt and automatics take a 45mm bolt?
That's the real mystery to solve.
Old 10-08-2018, 05:31 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
I'll go for "what are different crossmembers between manual and automatic cars?" Alex. For $3...
Old 10-08-2018, 06:50 PM
Rob Edwards
Archive Gatekeeper
Manual driveline loss, 15%. Rogerbox driveline loss, 20%. Manual rear crossmember cross section at e-brake mount: X mm. Rogerbox? X-5 mm. The Rogerbox crossmember is 5 mm thinner because it's protected from all that mean nasty power by the Rogerbox. Just like the torque tube only needing 4 bolts on the TC housing. Those Porsche engineers thought of _everything_.
Old 10-09-2018, 02:17 AM
R.Pires
R.Pires's Avatar
Hi,
First of all A BIG Thank You for all the help! This Forum is really something
After this reading and some inspection to the car (not easy because I don't have a lift...) i believe I narrow it down to the bolt that holds the emergency brake cables to the rear cross member.
I'm waiting for a vacancy on my mechanics lift to confirm and reinstall it.
I'll post here the result.
Once again, thank you all very very much!
Regards
Old 10-09-2018, 12:00 PM
hacksaw
hacksaw's Avatar
Please explain the increments on the tape measure.
Old 10-09-2018, 12:06 PM
Rob Edwards
Archive Gatekeeper
It's a metric tape measure, numbers are cm, gradations are mm.
Old 10-09-2018, 12:43 PM
R.Pires
R.Pires's Avatar
Exactly!!
Quick Reply: Help identifying a screw please!
