NorCal 928 timing belt party?
well I have a running 928 at home for the first time in about forever! Sean Finn’s street 87 s4 5 speed needs some attention and will be living with me for a while getting work done. First on the list is a timing belt water pump. Which water pump is best to use nowadays? Also which belt? We can do the work in my garage in Stockton but I have limited tools and need some skilled help, it’s been a long time since I did a tb/wp.
I propose a norcal 928 event at my house or another location and I’ll provide lunch-adult beverages for those willing to lend a hand and tools?
Chronic Tool Dropper
Hmmm. We moved from four hours south of you to eight hours north. I kinda miss having clinic days and a garage full of 928's. Good of you to carry the flag!
I agree with jeff about parts.....doc like the oem Porsche pump..... it’s pricey but so is a blown engine..pick your poison.
Update. I drove her today....sounds great with race style exhaust and runs strong....I’m not a fan of the short shifter but it works.....ran nice and cool on a hot day....lots of little things need attention.... however Sean says he changed the timing belt and put on a porkensior not long ago in terms of mileage....so I can address other things first like the AC.....
a question. The trunk is sticky at the lock...very hard to open.....hence I found it’s an early 87 folding wing...but still didn’t get trunk open....ideas on how to open it? I tried spraying some wd40 in lock....didn’t help....
Basic Site Sponsor
Basic Site Sponsor
The Laso pump is the only other choice that anyone should consider. (Using a metal impeller is retarded....so that eliminates the GEBA pump).
The Laso isn't as reliable as the factory pump, but 1/2 the price.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
The latch or the lock cylinder?
Try turning the key with the hatch unlatched & up a couple inches.
If the key still turns hard, it's the cylinder. If not, it's the latch mechanism.
Which one it is will determine how to address it.
In either case, I would suggest disassembly and a good thorough cleaning more than adding lube. If it's been sitting a while the old lube will have turned to goo. That may well be most of the problem.
What is being 'sticky'?
