Mmerlin: AC Part Question
PN 92860615000
It is my understanding, that replacing this part should not vent the AC, because it sits on a schrader valve...can you confirm this?
Yer about the smarted AC guy I know..and Ive never see this part discussed before.
I need to replace mine, and I have a full R12 system currently.
Archive Gatekeeper
Yes, there's a schrader valve in there. Should be ok to remove from a filled system. 19mm wrench to remove, 22 mm to counterhold.
Team Owner
What Rob said
Keep in mind that once you take it off the rad fans will default to full blast.
Chronic Tool Dropper
FWIW, this part virtually never fails. It's the transducer for system pressure, used to control the fans and flaps based on heat load in the high side of the system.
Jeff, curious what's leading you to replace the part other than for appearance.
Its rusted and ugly...the only part under my hood that looks old.
That's it..a new one isnt Cad plated like new was, but, its not rusty. This car sat for 9 straight years 2 owners ago under a tree.
Yeah -- there's a reason why there are plastic thumb-nuts on them for the electrical connections.
