Blaupunkt Related...Woodstock 88 pinout...
Archive Gatekeeper
Here's the schematic for that unit in PDF form. The pinout for the DIN connector is on page 6, you'll have to follow each pin to where it's bridged to the speaker outputs to infer the line level channel outputs and ground.
https://webfiles.uci.edu/redwards/pu...%208-27-18.pdf
Related thread that I just updated on pin labeling For the Reno SQR 46
https://rennlist.com/forums/audio-an...l#post15253577
The din pinout is going to be the same for both units being a similar vintage Blau or else they wouldn't be able to use the same 4 channel amplifier.
