928 Forum 1978-1995
Sponsored by: 928 Specialists
Archaelogical dig finds knock sensor in worst shape of all time
Old 08-28-2018, 01:26 PM
  #46
mark kibort
mark kibort's Avatar
Fred, I am not flying blind. i certainly do not have the resolution of the data available, as the ST2 would, but make no mistake,i have data. you can fly a plane using stars, landmarks and a compass and still get to your destination vs using a GPS..........
i have dyoed the car many many times over the years. air fuel ratios are in the 11 to 12 range on a stock ECU. sure, it is not fuel efficient but the loss of power as you go rich is minimum and assures safe operation.
Mark anderson had greg brown and crew do a shark tuner for a day, and they ended up VERY close in power compared to where they started with the technique ive used. timing? well, that is another area with suspect gains vs risk. you start narrowing this down,and you might move out of a safe range that im in now. again all the kings horses and men didnt find that much HP in the ST2 tune.
Then, when i look at plugs , brand new plugs after two weekends of racing, no street driving, and see that all plugs look good and identical, that is a very telling sign, would you not agree? I have a very unique condition to be able to do this.
as far as tune. i have a stock EZK bough form 928 interternational with its associated harness. the tune is stock S4. but there is factor custom chip in the LHbox that we dont know what it contains.
I understand the tuning cells, but really only care about WOT in a very narrow range. and by the way, it runs smooth as silk on the street too, getting decent gas mileage going to the track 18mpg or so.
Im clearly able to see what the timing is, and yet ive only done the checking of ignition timing at light load levels. (keep in mind, the flappy for example is load activated and is able to be triggered by blipping the throttle to high levels, which simulates a higher load) but its hard to do. i can now actually simulate load by getting the car on jack stands and use the brakes to allow for WOT operation in 4th gear at 4000rpm very easily. ill do this check today and see if the knock sensors are actually being read by the system as being connected. i would assume that if they are not, there should be some timing pulled out of the system.
now, Jeff has made it clear that the idle maps are different than the running maps and gave me a clue as to it being related to the idle switch . i dont know if that is the trigger to different maps for timing or not, of if then the sytem is using or looking at the knocks sensor, hall and temp sensors to determine if timing is to be remomoved... DO YOU KNOW?
sure, i would love to put this thing on the ST2 to see what is going on again . i assume not much has changed since bill ball checked it many years ago as the dyno runs are the same and the car feels near the same. however, i do want to make sure and should there be a chance to fix something that is not connected or broken, i want to do it now to take advantage of any hidden HP. for example, if that hall sensor is bad and its been taking out 6degree, maybe that would be hurting hp and has been since day 1. i dont know
as far as timing, sure the 2 valve and 4 valve are different, but how much. im measuring near 39 degrees at 4000rpm right now , with no load. (idle switch obviously not connected but then it wouldnt be in any case, so im wondering about jeffs point about "running maps) so, if this is a running map, i have a hard time believing that the timing would be 44 deegrees with..... also, even if it was, isnt it a general rule that many cars , like ours, pull back timing at the higher RPM for better power? if i looked at the sharktunemaps, i bet that is one of the thiings that it does. (but that is a guess). so, if i had the problem, wouldnt that might give hp or maybe not lose that much, as to be a resason, i havent suffered that much for this failure, if there is one .
currently, it seems llike the knock sensors are being ingored, and i want to make sure , and if so, find out why. i might be losing hp or i might not. its why i asked the question to anyone, if they have dynoed the car to see what a loss of 6degrees looks like on the dyno. sure, we would expect losses in the peak torque range,but maybe not much in the way of HP.
as far as stock maps, on the 2 vavle and 4valve, both came to me with the maps being in the 13.4 range. i fattened them up for racing and gained a little hp getting in the 12.5 range which seems to be optimal. going richer, doesnt lose that much, but too rich and you start building up carbon, and wasting gas (**** of your favoriate brand)
Originally Posted by FredR
Mark,
Without the likes of ST2 you are "radar blind" as to what is going on inside your motor engine management wise. I have lost count of the number of times I have tried to convince you about this but I do understand the concept that your "senses" are telling you the motor is running just fine and if that works for you all well and good.
As I am aware the Hall trigger enables the system to know which cylinder is knocking when a knock event occurs. If the system logic detects a fault in either a knock sensor or the Hall trigger it pulls timing 6 degrees across the board as a safety measure assuming that the fuel being fired is going to be no less than a certain octane no matter what type of witch **** it is.
As to the idle condition I have no idea whether any timing correction is applied to such - the likes of John or Jim will likely know that. I believe you are aware of the mapping system and how it works but for those that do not, the ignition system applies a certain amount of pre-defined advance based on a cell bounded by rpms and load [MAF reading]. The point of this map is to try to ensure that maximum cylinder pressure occurs at 14 degrees after top dead centre. Thus the faster the motor is running the more advance is applied and the lighter the load the more advance is applied - presumably because the mixture burns slower at lighter loads. Some operating cells buck the trend because of resonance effects or whatever else practical experience influenced the mapping in the factory. The stock mapping is a one size fits all type of thing and has a degree of conservatism built in for engine longevity reasons. Thus sharktuner permits tapping into that margin which is not an awful lot but is definitely present. I have no clue what mapping you are currently running on but my guess would be you have a custom EEPROM burnt using the original version of sharktuner- that or you simply have a stock map. If you have a custom chip then chances are further tuning will do nothing more for you performance wise but that does mean the likes of ST2 will do nothing for you- far from it. The ability to record data and analyse it is a huge plus in my opinion. Thus trying to assess what is going on when you blip the throttle on no load is just about meaningless unless you know the advance value for the cell the system is operating on when blipping the throttle which clearly you do not.
The other thing you need to remember is that what applied to your 2 valve motor does not apply to a 4 valve motor. The later models will have a more efficient [faster] burn characteristic thus need less advance on full load cells. Thus any notion that on full load and max rpms that you can run levels of advance much more than the stock mapping [27 degrees on a non cat model and 29 degrees with cats?] would be pure folly or so I would think. Similarly a race [faster] exhaust facilitates less advance- an interesting dynamic.
To summarise- you need to know whether your engine management system is working correctly and chances are that can only be reliably ascertained with some kind of system diagnostic capability. The hammer tells you whether it is working but little more than that. ST2 tells you this and so much more. Max power is seemingly delivered at around AFR 13 so running at AFR12 or less is for the most part a waste of fuel and at some point will actually cost you power. Stock mapping seems to give an AFR of about 12.4.
Old 08-28-2018, 02:09 PM
  #47
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,541 Likes on 1,228 Posts
If you don't know what the Hall sensor does (you asked about it less than 24 hours ago), you're flying blind. Type all the reply you like, but you're wasting your and our time until you can make basic diagnoses.
Old 08-28-2018, 02:19 PM
  #48
mark kibort
where did that comment come from? i know what it does.. it allows for the correlation of the knock with which cylinder needs to have 3 dgrees timing pulled out. right now, im concerned with if it is broken, (not working , connected) there should be 6 degrees if timing pulled out and i would like to check this. so what am i missing here Rob? im not flying blind if im trying to verify if all the ignition retardant components are actually functioning. In my mind , it should be an easy task,..........but i just need to know more about how and when the ignition retard occurs. I dont just like blindly replacing stuff, but as you saw, the knock sensor was known to be near death, so i felt it appropriate to replace it since i had the part on a table for 10 years. my main mission here was not to verify the knock sensor function, but it became a sub-mission. now, im more than curious. if the system is not respoding to the tests im doing,then is it the test or the system ,or another part, that has an issue. if there is a way to hook up the ST2 and verify this, im all for it. but i should be able to simulate running conditions, unplug stuff and see timing retards, no??
I'm not for wasting anyone's time, including my own... and what im doing is TRYING to verify.. can you offer some suggestions as to how to verify?
Old 08-28-2018, 02:30 PM
  #49
Rob Edwards
Archive Gatekeeper
Post #32, 2:50 PM, yesterday. Your quote:
by the way, what is the function of the hall sensor?
I interpreted your question to mean that you didn't know what the function of the Hall sensor was. So I posted a picture from the factory literature with a summary of the Hall sensor function.
I'm not (really) trying to be a meanie head, but you have come to this forum for 10+ years, asking questions about the state of tune of your racer, then arguing with the answers to your questions. It gets tiresome after a while. And it's 6 degrees of retard, not 3.
Old 08-28-2018, 02:41 PM
  #50
Rob Edwards
Archive Gatekeeper
Bring that fricking car to Sharktoberfest and we'll make it the tech session. We'll get an ST2 connected it and we can at least check the sensor status unequivocally. Deal?
Old 08-28-2018, 03:39 PM
  #51
dr bob
Chronic Tool Dropper
dr bob's Avatar
Don't even need the ST2. The sensor faults show up with almost any controller diagnostic tool north of a flashlight.
Old 08-28-2018, 03:44 PM
  #52
Rob Edwards
Archive Gatekeeper
Ok, Bring that frickin' car and we'll hook up my spanner, or my Theo tool. Operators are standing by.
Old 08-28-2018, 04:21 PM
  #53
merchauser
merchauser's Avatar
that's a sweet offer, and its nice to see the great spirit that exists on this forum!
Old 08-28-2018, 04:48 PM
  #54
mark kibort
It is quite amazing. i know i get a lot of smack here, but the guys have saved me , my entire racing career. ive learned more than i could ever imagine.
Yes, i will!! or how do we get that "flashlight" to help me locally. dont have much time, not a lot, but i want to stop thinking about it and get it ready for the event.
any suggestions? something i can plug in at CT automotive, and would assume they have high end tools there.
that sounds fun! i think i will!
I meant to ask more about what it did when disconnected. and yes, you are being a little bit of a meanie! my questions along the way have been very purposed and pointed to real issues. we know it runs and runs safe, i just have questions when thngs go off the beaten path a little. and by the way, i hate to correct you ,but its "3 degrees" not 6, as i said for knock adjustment, until it sees more and as i said again, 6 degrees if the sensor is not connected, as when the temp, or knock are not seen as connected.
so, it seems like a LOGICAL question. if all this eletronic test equipment is going to register knocks, see timing changes, etc.. all i want to do is simulate it on the car running with a timing light. why does this not sound like a PERFECT way to verify if the devices are working, or if the system is working? i just need to know, is it only changing under load or is it only RPM or is it a little of both. Jeff eluded to it, and then he went away.... he left us with " running maps" and some teasing questions.
Old 08-28-2018, 06:00 PM
  #55
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Again:
If you dont see change with your timing light when you unplug something, then you probly have a problem elsewhere.
There should be change.
Old 08-28-2018, 06:34 PM
  #56
mark kibort
Originally Posted by Speedtoys
Again:
Again........just be clear, because i want to understand. ....not at idle (you asked me and commented about running /WOT maps) , but everywhere else , regardless of throttle position or RPM? you made a comment about. new knock sensors? temp sensors not working? the only thing that i could think of failing , might be the hall sensor . since ive already measured 38degrees advance , how could that be 6 degrees off??? I've never heard of timing that advanced .. im just amazed no one has taken a light to the engine and old school looked at what the timing should be or is. the other thing, is since we have the one variable... maybe the Holbert ECU ignores all warning /failure feedbacks. does this feeback exist in the LHjettronic box or is it a EZK thing? the only thing that is stock, is the EZK. Anything is possible at this point.
where do you think the problem is?? where else can i look? is there a tool that can check the hall function?
Old 08-28-2018, 06:42 PM
  #57
Speedtoys
Speedtoys's Avatar
Yes.
Old 08-28-2018, 06:49 PM
  #58
merchauser
merchauser's Avatar
bosch hammer will tell you if the hall sensor is working
I had a fault code that read short to ground; I found that the wires to the hall sensor were a bit scrambled,
and the connector at the sensor crumbled like a cookie
repaired the wires, and replaced the sensor, and it felt as if I had install a performance chip. amazing.
FWIW: there was no difference at idle, only on acceleration.
Old 08-28-2018, 07:43 PM
  #59
mark kibort
yes, the connectror from the sensor into the harness was cracking but i put sealant over it and stabilized it from bending . the hall sensor wire coming out of the pulley cover plate looks good. what is a bosch hammer? a type of diagnostic device. im worried that i dont have the correct plug for any of these devices to check things. Bill ball would know. maybe its worth buying a new hall sensor. i first want to verify. there should be an easy way to do this with timing checks. compare to another S4. it seems simple enough.
Old 08-28-2018, 07:48 PM
  #60
dr bob
dr bob's Avatar
Mark--
You have the needed tools local to you. Jeff has repeatedly offered to connect to the car with the ST; even if just for basic diagnostics it's a worthwhile effort.
Basics: If "fixing" the rear knock sensor didn't noticeably improve acceleration throughout the load range, you have another fault to hunt down. Both the knock sensors and the Hall sensor have shielding on the cabling all the way from the controller to the sensor. You can do basic Ohm meter checks from the controller plugs to see if any are shorted to ground (shield). If you unplug the controllers, you can test for that with a flashlight if you have to. A DMM is handier and safer though. You can provide a little DC excitation to a knock sensor, and connect the signal leads to a spectrum analyzer to see what all the mechanical rattling looks like. Or to a basic O'scope to see amplitude alone. O'scope will display the signals from the Hall sensor that go high-low-high-low as the cam turns. If you can't see these basic signals at the controllers end, you need to hunt down the problems. Sensor(s) or wiring.
Throughout this thread and in many related threads, you bombard your support team with your theory that if the mixture is always OK to a little rich on the WBO2 then the car is perfect. Each time someone on the support team attempts to educate you on even the most basic and maybe mundane issue, you dump a load of perhaps loosely-related internet "facts" on them in an attempt to not fix whatever it is that's actually wrong.
Have you followed ---ANY--- of the guidance shared on cam timing? Have you found the vacuum leak? Have you looked? How well balanced are those exhaust port temps at idle, when you have the slight miss that you can only seem to hear at idle? Got a set of known-consistent injectors installed yet? Any basic performance effort really needs to work from a known-good baseline condition where everything is at least as good as the factory intended.
Thought: Don't show up at Sharktoberfest (or at Jeff's) with a list of neglected stuff to work through before the experts can help you with performance tuning.
I know that Rob logged a LOT of data on his way to getting his GTS stroker to where it is now. Jim & Sue had the benefit of dyno time on the GT engine before it went in the car, chassis dyno time after it was installed, and a bonus trip to Palm Springs and Phoenix for more tuning. Then more on the ride home. This is the guy that built the Sharkplotter add-on, so there's a real possibility that he knows what he's doing. Results still are not instant.
Quick Reply: Archaelogical dig finds knock sensor in worst shape of all time
