Rescued 86.5 - 5 Speed
OK so needs body work and paint.....Interior work, and the mechanical condition is unknown. The fuse panel board being removed infers that some one some time was TRYING to get it to run. Lots of potential here to spend $$$$$$$ . But certainly can keep you busy. !!! .Put a timing belt on it and try to get it running as cheaply as possible BEFORE buying tons of parts forget about doing all the front end water pump rollers etc. If the engine runs and the clutch trans etc. work Then and only then do you have a car. That means you can pull the engine and do a reseal including the head gaskets etc etc etc.
Soontobered,
Not a flood car. It was in Dallas not Houston. It is a theft recovery from Georgia.
BauerR,
I will send you a PM.
James Bailey,
That is my plan. It will be a slow process. If it doesn't go as planned I will keep it for a parts car.
Hacksaw,
I appreciate the parts offer. I will PM you if and when I get to the body.
BauerR,
James Bailey,
Hacksaw,
