928 Forum 1978-1995
Sponsored by: 928 Specialists
Spark & Fuel Diagnostics
Old 01-14-2004, 07:56 PM
Rich9928p
Rich9928p's Avatar
Default Spark & Fuel Diagnostics
I’ve observed that many 928 owners are trying to diagnose problems with their cars. I’m pleased to share some of the facts I’ve learned since I began providing LH module rebuild service. I must advise the reader that extreme care must be taken when working near high voltage spark sources. If you DO NOT KNOW WHAT YOU ARE DOING, DON’T DO IT. You can hurt yourself and damage your car. Have a qualified Porsche technician do the work, in the long run you’ll save money (no self-damaged parts) and you won’t get hurt. Odds are your Porsche shop may not know this detail of information, so feel free to take this information to them, it could save you money by reducing the time required and improve the quality of the diagnosis.
There were two different generations of LH fuel injection controllers used during the life of the 928. The 1984 – 1986 Euro/ROW and 1985 – 1986 US/Japan model 928s used an 8039 microprocessor-based design and have a 25-pin connector to the module. For model years 1987 to 1995, the LH module was based on an 8031 microprocessor and the increased functionality required a 35-pin module connector. Spark control also was supported by two different generations of modules. The 1984 – 1986 Euro/ROW and 1985 – 1986 US/Japan 928s use a 25-pin EZF controller and an inductive RPM pick-up and had a vacuum coupling provide engine load information. From 1987 onwards, a 35-pin EZK module was used. The EZK had a three-dimensional RPM, engine load and spark advance map stored within the ROM code, so no vacuum connection was needed.
The EZK system used an inductive pick-up for RPM signals plus a Hall Effect sensor to recognize which ignition coil gets the next spark signal. Also, knock sensors were added to the spark control system. On-going improvements and fine-tuning were achieved by changing ROM codes, so modules were often specified to specific year applications.
When diagnosing no-start situations, ALWAYS clean and tighten connectors, check ground connections and inspect for broken wires. Only after those potential problems are checked-out should a module failure be investigated. The 928 workshop manuals are a necessity for diagnosis, the system is complex and the interconnections are not intuitive. Here are some hints to follow if your LH-equipped 928 isn’t starting or running well.
It is not commonly known that the LH fuel injection module is slave to the EZx spark control. So if you have a no-start condition, always check for spark first. If there is no spark, fix that problem before testing for LH ECU functionality.
The EZx spark unit looks for rotation pulses from the engine RPM sensor as a condition to start the spark system. The EZx then turns on the LH ECU, so a bad EZx ECU may cause the fuel injection not to work. Therefore, always check for RPM pulses from the sensor located at the top of the bell housing for a no-start & no-spark conditions.
Both systems use the inductive sensor (master-sensor). Inductive RPM sensors generate voltage so a VOM can be used for testing. For the EZF, it is connected at pin 19 and 7, where pin 7 is connected internally in the ECU to pin 12 (master-ground). Pin 20 is the shield of the sensor cable and is connected through internally to master-ground pin 12. For the EZK, pins 23 and 6 are used where pin 6 is connected to master-ground pin 18. Pin 24 is the shielding of the sensor cable and is connected internally to pin 18.
Hall Effect sensors can be tested with an LED tester. The EZK generates the Power supply for the Hall Sensor at pin number 5 (12V). The EZK generates a 5V Level at pin number 22, which the Hall sensor can pull down to ground. Pin 22 is the "hot" signal cable and therefore is shielded. The cable shielding is connected to pin 4, and pin 4 is connected internally to master-ground pin 18.
The EZx spark and LH ECUs are under relay switch power control. First verify that voltage is present at both LH and EZx relay pin numbers 30. There should always be voltage at pin 30, regardless of the ignition key position because a direct circuit is provided from the battery. If voltage is present, next jumper pins 30 and 87 and attempt to start the engine. If it starts, there is a relay or control signal to the relay problem. If it doesn't start, you may have an ECU problem.
The LH ECU controls power to the fuel pump. If there is a "no fuel pressure" situation, first verify that the fuel pump fuse is OK. If the fuse is OK, next check for voltage at fuel pump relay pin 30. If voltage is present, jumper the fuel pump relay (pins 30 and 87) and check for a running fuel pump. If the fuel pump runs, there is a relay or control signal problem to the fuel pump relay. If the fuel pump doesn't run when the relay is jumpered, there may be a fuel pump or wiring problem to the fuel pump. One of the symptoms of a failed LH module is no "turn-on signal" to the fuel pump relay.
For 1984 – 86 model year 928s, the fuel pump relay is the source for voltage to the fuel injectors and the LH module provides the fuel injection current path to ground. Therefore, a bad fuel pump relay can also result in no voltage to the fuel injectors. The fuel injector voltage source was changed to the LH relay for model year 1987 and newer 928s. In 1989 an ignition circuit control was added as a safety feature to open the fuel injection circuit (stop injection) if no heat is found in the exhaust stream. Look for this module in the passenger compartment near the EZK and LH modules.
A simple way to determine if the “hot wire” Mass Air Flow sensor is working is to disconnect it and start the motor. If it runs better when the MAF sensor disconnected (in limp-home mode), then the MAF sensor is likely failing.
As crazy as it may seam, cars are different. A friend of mine had an LH module that would work in other cars, but not in his, so he spent many more weeks looking for the problem in other areas. The “suspect” LH module ultimately failed, even in other “test cars,” when only a few weeks prior it was running fine.
If you have some specific questions diagnostic questions, please feel free to send me a note at info@electronikrepair.com.
Rich Andrade
www.electronikrepair.com
Old 01-14-2004, 09:04 PM
Rez
Rez's Avatar
Good post Rick!
Old 02-19-2004, 02:34 AM
Rich9928p
Rich9928p's Avatar
Part II: The The Ignition Circuit Monitoring Relay
The 928 S4 and newer engines have two separate ignition circuits. Ignition circuit 1 is comprised of cylinders 1,4,6,7, the right side coil and distributor. Ignition circuit 2 is comprised of cylinders 2,3,5,8, the left side coil and distributor. If there is a failure in one of the ignition circuits, raw fuel is pumped out of the cylinders and into the exhaust system. When the raw fuel hits the hot catalytic converters a fire may occur – OUCH!
From model year 1989 onwards, Porsche added the Ignition Circuit Monitoring Relay as a safety feature. This circuit is completely independent of the LH injection system. It is identified in the workshop manual wiring diagram as the Ignition Control Circuit. The function of the system is to turn off the fuel injection to the failing ignition circuit. The inputs to the relay are two exhaust temperature sensors that provide input to the relay. If one of the ignition circuits fails, the “Ignition Circuit Monitoring Relay” shuts off the pulse signal to all of the fuel injectors of the affected circuit.
As you might imagine, the symptoms of a shut down ignition circuit are a significant reduction in power and a rough running engine. For trouble shooting, you need to determine if the shut-down is due to a failed ignition circuit or a failure of the Ignition Circuit Monitoring Relay itself.
The first step is to quickly identify which circuit is affected. Look at the clear relay module that is fitted next to the EZK spark control unit in the passenger compartment.
When ignition circuit 1 (cylinders 1,4,6,7) is shut-down, a red LED is illuminated.
When ignition circuit 2 (cylinders 2,3,5,8) is shut-down, a green LED is illuminated.
Check the ignition circuits and repair as necessary. If no problem is found with the ignition circuit, there may be a failure of the Ignition Circuit Monitoring Relay circuit, the signals to test are:
1. Terminal 31: ground
2. Ground must be present at terminal AL when the ignition switch is in the off position.
3. Battery voltage must be present at terminals A1, A2, 15 and 87 when the ignition is in the on position.
4. Battery voltage must be present at terminals AL and 61 when the engine is running.
5. A Voltage value of approximately 2.7 V must be present at both terminals E1 and E2 when the ignition is in the on position.
6. The resistance between E1 and E1 is approximately 5 – 10 Ohms (measured at the disconnected relay socket).
The temperature sensors that fit in the exhaust system should also be inspected.
A more detailed explanation is provided in the factory workshop manuals.
Old 02-19-2004, 12:45 PM
Realist D.
Realist D.'s Avatar
The second post is a good one! I once had the problem where half the engine shut down. Since my car is an '88 I was pumping raw fuel through those 4 cylinders causing the cats to become red hot and flames to shoot out the exhaust (wow! - I was on-track at Mosport when it happened). Using my old-fashioned troubleshooting knowledge I quickly determined that one coil wasn't sparking and thought I could fix the problem easily by replacing the coil. Unfortunately these cars are way beyond my 1970's era knowledge base. The new coil didn't solve the problem so I had to send the car to my local 928 guru who quickly identified a defective "ignition control module" which he replaced for $60.
Old 03-19-2004, 01:55 AM
MBMB
MBMB's Avatar
-snip-
-snip-
Resurrecting this thread with a thought: if you have to limp home with a shut down ignition circuit or overrich mixture (or other condition that might be dumping fuel into the cats), would it not make sense to disable the air pump before proceeding, so that you have less chance of combustion in the cats? Or would the difference be insignificant?
Old 03-19-2004, 02:38 AM
Rich9928p
Rich9928p's Avatar
>> If there is no spark and the injectors are pumping fuel into the cylinder, this "ripe" mixture is just pumped from the cylinders out the exhaust. So the mixture is perfect for combustion. There would be some mixing of the "ripe" mixture with the exhaust from the cylinders that are firing, but there would be enough fuel to burn. I would think that the difference would be insignificant given that there are reports that many cars have burned from this problem.
Old 03-19-2004, 06:07 AM
UKKid35
UKKid35's Avatar
Rich, have you modified your '87 S4 to include an Ignition Circuit Monitoring Relay and the associated exhaust temperature sensors?
Old 03-19-2004, 02:32 PM
black928shark
8th Gear
black928shark's Avatar
Rich, excellent post, I have been dealing with a no start with my 86. When I get back to the U.S. i will do the trouble shooting as you stated in Part I. If it my LH you will be hearing from my. Thanks for the info.
Quick Reply: Spark & Fuel Diagnostics
