K2 Spring
K2 Spring
Hi All,
Refreshing my transmission valve body, new K1/K2 springs and adding gasket to separator plate, along with new B2 piston with guide in main body. Found my K2 spring had imploded which explains the 3 -> 4 flaring.
Should I just put this down to fatigue or is there something else I should check before putting everything back together?
The bore is smooth other than some scratches at the base.
Thanks,
Gary
'86 Euro Auto
Thanks,
Gary
'86 Euro Auto
Former Vendor
Good find!
Springs do fatigue and break. There's really nothing else to look for....there's no other cause.
What are you replacing both springs with?
Former Vendor
And apparently a new piston!
I'd love to know that part number, if you have it.
Mercedes, here, is not much help. If you don't give them a vehicle VIN and a transmission number, they don't want/claim they can't help.
K1/K2 spring replacement
K1 Valve body kit and K2 Thrust pin kit
Not sure if this is of any help but the Mercedes part numbers are A1262700335 for the K1 valve body kit and A1262704477 for the K2 thrust pin kit. Inexpensively sourced from local Mercedes dealer. (The spring wire thickness, coil number and configuration has slightly changed on the superceded part)
Other/old part numbers are 1282770932 (K1 body) and 1282771032 (K2 body).
