OB experts, help me with 2 quick questions please
Ok the car in question is my 1978 928. I had to replace the main wiring loom in the engine compartment, not the engine loom but rather the one that penetrates the firewall.
1) The washer fluid pump. This little pump that sits below the coolant overflow tank looks like it mounts to a bracket welded to the inner fender well, see picture 1 below. The bracket has wholes for the nibs both on top and the side facing the rear of the car, which side does it go on?
2) The four wires the run the headlight lift motor were disconnected by the previous owner see photo # 2. The plug is numbered 1-4, can someone tell me what color wires go to each of the numbered barb on the plug?
Washer pump bracket
Headlight motor plug
Washer pump bracket
Its all here mate, ya just have to refer to search function.eg.
https://rennlist.com/forums/928-foru...onnection.html
Q1 Answer - pump faces the engine bay. 3 nibs IIRC.
