928 Forum 1978-1995
Sponsored by: 928 Specialists
'79 928 auto starts fine dies when gas is pressed
Old 07-13-2018, 03:24 PM
reimen
2nd Gear
reimen's Avatar
Default '79 928 auto starts fine dies when gas is pressed
Hello! This is my first post to this forum. Thanks to Wpgshark for pointing me to it.
Recently, my "OB" 928 started to have a hesitation when accelerating. At times it was a second or two before acceleration would kick it but then would run fine. Even more recently, it has begun to simply die out when the gas is pressed. I was hoping someone might have a few suggestions for a new 928 owner. As I mentioned in the title, it is a 1979 automatic.
thanks!
Nathan
Old 07-13-2018, 04:58 PM
dzaprev
dzaprev's Avatar
Follwing
Old 07-13-2018, 05:26 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
your going to need to check the control and operating pressures to figure out the issue ,
Roger has a set of Gauges.
But off the bat I will say you probably have a vacuum leak,
once the pedal is pushed the system goes to a leaner mixture then it stalls.
If a vacuum leak is not found the gauges are needed
Old 07-13-2018, 05:51 PM
reimen
2nd Gear
reimen's Avatar
Thanks for your reply!
Because of your message, I did a search for "vacuum leak" and found a great article on Rennlist about possible reasons for hesitations: https://rennlist.com/how-tos/a/porsc...itating-378349
Very helpful.
cheers
Quick Reply: '79 928 auto starts fine dies when gas is pressed
