More Help Needed Guys.....No Injector Pulse
Ken, thanks for your input. I used your test method and found a dud injector. Pulled the injector and hey presto, my noid light is blinking. Connected everything back up and she fired on the first crank.
So again, thanks to you guys I got her started. I would truly be effed without Rennlist.
Nice job guys!
No injector pulse or fuel pump power
the fuse box and it shows the kick down relay in it and couldn’t figure why this
1985 wasn’t getting pulse and fuel pump power and indeed it was the relay and I guess my car doesn’t use it and now starts :-)
thank you
john Speake you are a genius, I been going crazy with this issue and I got a copy of
thank you
thank you
