78 OB Motor Mounts / Engine Vibration above 4000 rpm
Is this motor rocking enough that the mounts look good? They aren’t torn, but are a bit cracked. I just replaced both of the vibration dampers. I’m trying to track down the source of a vibration that comes on around 4K rpm and continues up to redline. Almost like a growl (full engine growl for lack of better explaination), it can also be felt in my feet by the firewall while reving the car. Car has lots of power and runs smooth up to this point. It also has lots of power through this vibration up to redline, but it obviously causes me to back off and keep the revs under 4K. The vib is there in neutral parked in the driveway or in gear and clutch pedal up or down makes no difference on vibration.
I’ve recently refreshed the clutch pack and it was balanced at a machine shop with new throwout and pilot bearings installed, so I think I can eliminate that.
New torque tube bearings from Black Sea, but because the vibration is still there when the clutch is disengaged does that isolate it to the engine?
I’ve also replaced plugs, wires, cap, rotor, coil, fuel injectors in case it was caused by a misfire, no luck
Originally, I was hoping this vibration was part of the pilot, throwout or torque tube bearings failing because they were making noise, so it’s been there the whole time, but was just lurking behind those bearing noises. Changing those hasn’t helped with this vibration
Any ideas?
Team Owner
please inspect the transmission mounts ,
probably collapsed
probably collapsed
They look ok to my untrained eye, ie. not torn or severely cracked, but I think I’m going to replace them and the motor mounts just to be sure. Just have to get them ordered from Roger. Thanks for the reply Stan
The factory mounts are solid rubber in our early cars so maybe yours just needs a fresh cap and rotor along with a fresh set of plugs to get it smooth again.
Team Owner
yes, the old style mounts dont rock like the Volvo mounts do ,
but the trans mount still collapse and this can cause the trans to sit on the crossmember
Anybody know where this trans vibration damper (12) is located? I’ve been under the car and dropped the trans a bit when I did the torque tube, but haven’t seen it.
Update: Trans mounts replaced, vibration still the same. I think I’m moving towards motor mounts next, unless someone has any other suggestions. I know they are the solid mounts, but maybe the rubber has torn away from the metal, who knows?
Engine crank damper would be my guess.
+ 1 on damper...I had a pretty strong vibration above 4k and elected to replace it with on of Greg's Super Dampers and was one of if not the best investment I could make in terms of extending the longevity of the original engine. 4k vibration gone and runs super smooth...def. put a new damper on it...they're made of rubber...so not really reasonable to expect a 40 year old hunk of rubber to do what itneeds to do in this case..not saying it's impossible...but to me...improbable...
Josh,
When you do receive both parts...please replace them one at a time, checking for vibration between installations. That way, if one resolves issue, we have a definitive answer. Your car seems to be coming along nicely! Old red is just resting this summer, to hot for this old man to do anything...lol.
Brian.
Brian.
Josh,
Brian.
Brian.
Good to hear from ya. Parts should be a few weeks. Sounds like I may get the motor mounts in first, although I wanted to do the balancer first, so we’ll see. When I do do the balancer I’m gonna change the water pump, rebuild the tensioner, front crank seal, oil pump seals and cam seals, and the timing belt. I’ll definitely do the balancer and mount motors one at time. The car is coming along, thanks. I just got my a/c blowing ice cold and other than this vibration the car is running and driving great. Once I get this figured out it will be on to the exterior, paint, weatherstripping and finish off the interior, but that may next year. We should get together sometime. I’d love to get a second set of eyes and ears on this vibration. Take care buddy
