harness bolt
harness bolt
Im replacing the engine harness with one of Seans wiring with a GB alternator; do I have to remove the timing belt covers to get at this bolt? (I think I do)
red arrow bolt. (picture from the Dwayne t.belt epic)
13mm on an extension and you can get it out and put it back in.
I got the bolt out as Sean described but I went in from below and worked somewhat blind as the bolt head is quite recessed.
With the bolt out, the air filter housing off, the injector rail cover off and a series of disconnections at the 14 pin, alternator and starter the old and now dead harness is out.
