PSD reservoir overnight soak? PSD leak
noticed a nice puddle of brake fluid on garage floor just behind drivers rear wheel. upon inspection,
reservoir was empty. at the bottom is a good deal of debris. took off resv and sprayed with brake
cleaner, but still a good deal of crud at the bottom
is there a "safe" chemical I can use to soak the reservoir in to get that stuff out? I have denatured alcohol,
lacquer thinner, acetone,..?? any suggestions?
pretty sure that the resv is not leaking, but not sure where it is leaking from. it could be from the hose
with the banjo fitting, leaking at the banjo? it appears to be coming from below the pressure accumulator,
and more towards the passenger side, below the pump.
is there a more "common" point of leak on these systems?
Never heard of these things leaking fluid before. As with anything that contains liquids and leaks there has to be a leak path and inspection should have suggested where it is coming from but if you have removed the reservoir then that has been compromised to some extent. Presumably the reservoir has a grommet problem and/or maybe a crack in the plastic? I understand those things are difficult or impossible to get hold of these days- doubtless Roger can shed some light on that one.
I have heard of these things having to be rebuilt and some chap in Germany does this apparently. I seem to remember a thread with a video link not that long ago not that you would want to do such.
The DOT 3 fluid is a PEG [polyethylene glycol] and as I understand it dissolves in alcohol- do not try to use gasoline or diesel to dissolve.
thank you fred.
to be clear, the reservoir does not appear to be the source of the leak. it may well be the banjo fitting
and/or corresponding hose. since it was empty, it must be at a lower point?
so from your perspective, there is not a "common" leak issue.
still wondering what might be the best fluid to soak the reservoir in
I've used brake kleen to clean some pretty nasty PSD reservoirs after removing the internal filter. Takes a lot of scrubbing and unless you split the reservoir at the seam you'll never get it completely clean due to how it is plumbed.
Kevin
Kevin
thank you fred.
https://en.wikipedia.org/wiki/White_spirit
Åke
how to reseal properly
I always have White Spirit in the workshop
dissolve the debris?
Basic Sponsor
I hope it does not come to this but we sell rebuilt PSD units.
I did not mean to imply I had split it, but you will note that the return route to the reservoir goes to a part of the reservoir that cannot be reached for easy cleaning. Having said that using a box cutter or similar tool you should be able to separate the reservoirs at the seam.
I may do that myself.
Kevin
Kevin
As for leaks - I would examine the place the motor and pump meet. There is rubber gasket/o-ring that separates them. And a good look at the supply and return hoses, too.
Paul, do remove the filter out of the reservoir and you can clean it properly (see post #17)
https://rennlist.com/forums/928-foru...procedure.html
Åke
Åke
thank you fred.
Hopefully not the case in this instance but...?
the plastic elbow for the lower hose on the reservoir. behind that is an O ring as well??
Basic Site Sponsor
Basic Site Sponsor
Brake fluid is water soluble. Don't use any cleaner that is oil based. Alcohol or just plain water works the best.
If the pump runs, fill up the reservoir, turn on the key, and allow the system to pressurize.
The most common leak is from the high pressure accumulator splitting a seam and spraying fluid out at very high pressures (they usually will not leak until the pressures are very high.)
Don't stick your fingers in there to "feel" for the leak.....there's enough pressure involved to cut your fingers right off (if you are lucky). If you are unlucky, the fluid gets injected under your skin. (In the military, they say this will kill you, before you can reach the hospital.)
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
This is the o-ring. I have not found a source for them - I could use a couple.
