MY 1990 Power Mirror Change Over Switch Wiring
MY '90. While removing the door panel on the driver side, a couple of the 6 pins for the changeover switch fell out because the cover was not snapped on to the connector. I put them in which I thought was correct but now the passenger mirror only works in the horizontal position left and right and not correct on the directional switch. Push the switch in the vertical adjustment position and it moves horizontally and is dead vertically. The driver side works correctly. The colors of the wires in the WSM don't correlate with what I have. At a loss without the GTS here to look at the switch. The second pic is the change over switch.
Archive Gatekeeper
I don't have '90, but I have '89. Will check the wiring diagrams and get back to this thread.
Rob, Your picture is what they say "worth a thousand words". The 6 & 4 and the 5 & 3 pins were switched. I got the wiring corrected. I had just got it back from the body shop for respray of the door. I found that connector cover loose and the pins falling out. They must have guessed when they put it back together. Got it all secured and both mirrors working properly! Rennlist subscription worth all the money. Thank you, thank you, Rob
