‘78 Clutch and torque tube bearing replacement with hydraulics, Need some help/advice
I have a 1980 928S Euro. This discussion is targeted to the 78-79 but doe sit also apply to the 1980's? If not, what were the changes. My clutch seemed to be intermittently dragging which caused it to be difficult to get into any gear. Replaced the clutch master and slave cylinders but still have the problem. I haven't tried all the bleeding items in these posts but I will. I also haven't compared the internals of he master from what I believe is the original (at least it hasn't been replaced since 1985 when I purchased the car) to the new one.
Mike Lemons
Mike Lemons
Basic Site Sponsor
Basic Site Sponsor
And I thought I have seen worn shafts....
That's amazing!
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Thanks for your reply. Guess I just wasn't getting it bled enough. Took the slave off, turned the bleed valve up and the trapped air came out. Put back together and all seems to be working good. Thanks again.
Mike Lemons
Mike Lemons
Update...
Clutch is working great. I just wanted to add a few helpful tips I learned through the process of this job.
-when lining up clutch pack on the work bench before installing in car. Get all pieces in the correct order and lined up then gently tap the pressure plate evenly with a rubber mallet into the intermediate plate. It’s not a tight hold, but it’s enough that if you are gentle with it while installing the pieces it will not fall apart on your head during the critical alignment phase under the car.
- replace the guide tube while doing this job. It’s a $60 part. I didn’t and experienced some clutch rattle (stuttering or juttering) while down shifting, when reversing and slow starts in first. I went back in and found my guide had worn (tapered) down 0.6 mm. I feel silly I missed this when doing the job originally, but whatever, it’s fixed now. The clutch now feels like a million bucks with the news parts and the new guide tube.
