LH & EZ-K Carpeted Cover Part Number
To you all knowing 928 gurus, I am looking for the part number and availability of the carpeted and insulated cover that fits over the computers in the passenger foot well. Mine is cracking and crumbling. I need black for an 91 S4 if anyone happens to have an additional one in excellent condition. I have searched through PET and online to no avail.Thanks in advance
That cover is built into the front floor mat. On my 88 it was missing completely. Rob Budd sells a front floor carpet set that has the cover for reasonable money and may make just the one side for you. Give him a call.
Hummm I think the one on a '91 is a separate part, uses a black plastic like wing nut and not the snap and strap.
The back of the part has a few plastic pins that fit into holes at the rear of the ECU's
Dave K
Dave K
Received 1,207 Likes
BTW, I fixed mine because of the same problem.
I used some "Flex Seal" (if I remember well) and painted it in black after.
I took some pics when I did this job.
Can post them tonight if you want.
Edit: Or maybe it was the insulation part... Not sure.
Yes, mine is separate and I have epoxied it but it continues to break so I'll have to continue to glue it together unless I can source another. Thanks Dave and Bertrand
Basic Sponsor
928 551 010 08 5FV - Black
$400
I can't check availability as the Porsche system has been down all afternoon
$400
I checked and it's the insulation panel that I fixed. Sorry.
Anyway, here's what I did. Maybe it would work for your part.
I put a layer of Weather Shield Flex on the rubber side, brushed it to smooth the surface a bit and painted both sides with a few thin coats of Plasti Dip.
It worked great!
It worked great!
Wow! Roger that bit is pricey. For that money I'll continue to to piece it back together until it is un-salvageable. When that time comes and if it's available I'll shoot you an email.
Thanks Bertrand for the info. The insulation on mine is fine but the plastic has become brittle.
