Look ma, no alternator cooling hose
https://cimg5.ibsrv.net/gimg/rennlis...cc3bce26b.jpeg https://cimg6.ibsrv.net/gimg/rennlis...92b97e1a2.jpeg https://cimg7.ibsrv.net/gimg/rennlis...8f2c84566.jpeg Started excavating driver side wheel well to check on outside air sensor. In our 84 manual, there was a hooked air tube there, which housed this sensor. Upon dissecting the 85 auto, I find no such tubing. There is a support bracket in the wheel well wall, but I find no hose connection point at the alternator. Is the hose not part of the 85 system? Is this an aftermarket alternator? Thanks and peace, Tim |
I don't know if you have the correct alternator, but you are missing the rear cover which allows for the hose to
be attached. PET calls it an alternator cowl and part number 928 603 133 04. |
Hi Tim,
That looks like a replacement alternator. It doesn't look like it is compatible with the 928 cooling duct and shroud system. If it's working OK, you might keep it for a while. Otherwise Roger has the correct alternator, shroud and cooling duct that you can put your outside temp sensor into. Good luck, Dave |
That alternator is a Bosch unit (from the decal on the side) and I see at least one bolt that has enough length to support the cowling, washer and nut to which the air tube would connect.
I do question the ride height that you are running since you have definite road rash on the side of the alternator which usually means your ride height is too low or that your have been stunt driving. Have you been stunt driving again? :) |
John Curry is right. I can't read the model number, but it would be great if you could simply buy the shroud and ducting from Roger.
Good luck, Dave |
Is the fan shroud missing as well?
Is your car 84 or 85? The alternator looks correct for 85-95 and those covers are still available
http://shop.928intl.com/Used-Alterna...28-603-133-07/ the 78-84 covers are NLA |
I need to make the official request for the sensor shown and the hose described as missing. I do believe that the posters are correct about the alternator. Where may one procure the sensor shown? |
Originally Posted by WALTSTAR
(Post 15010216)
I need to make the official request for the sensor shown and the hose described as missing. I do believe that the posters are correct about the alternator. Where may one procure the sensor shown? There are also great folks at http://shop.928intl.com. |
Originally Posted by soontobered84
(Post 15008280)
I do question the ride height that you are running since you have definite road rash on the side of the alternator which usually means your ride height is too low or that your have been stunt driving. Have you been stunt driving again? :) Dave, I’ll talk with Rog about the housing and tube. As always, you’re the best. |
Originally Posted by 84totheFloor
(Post 15010347)
This is a good call on your part. I have thought the alternator height might be too low. Have been extra cautious over bumps since noting that under the car. I'm just a little more observant about that particular thing than most folk after seeing that. :) |
Hi Tim,
That sensor in the alternator duct hose is important to the operation of the climate control. Without it connected, the climate control operates like an on-off switch. It will work ok, but with a slow response, without the duct, just sitting loose(ish). Good luck, Dave |
I searched both vendors sites for said part and could not find it. Could one of you fine chaps connect me with the part(s)? |
Don't bother with the site, give him a call or send him an email. Very responsive, and he has many MANY things that aren't on the site.
(Post 15014827)
