Who's prestine 928 is this on Motorweek's Goss's Garage
GTS
Most recent episode of Motorweek (Season 37 Episode 35)
Administrator - "Tyson"
How can you tell it's pristine? Hood is closed, cannot see the jump post cover.
Received 1,542 Likes
Yeah he was talking about older systems upgrading to LEDs or Xenons that they don't always work for the oncoming car.
As a good example, he said that new SUVs with LEDs have their headlights pointed slightly downwards because of their height advantage over cars.
So if you put LEDs in an older SUV, the oncoming car gets blinded.
I guessed GTS because of the rear fender flare.
Not a GTS, the rub strip goes back to far, mirrors are flag not sport and the fender doesn't have the bulge.
I must have watched a different episode with the same two cars in the background, all he spoke of was changing Trans fluid, stated that the Torque Converter would still contain old fluid unless you used a Fluid exchange system.
He never mentioned the 928, or the fact that it has a Torque Converter drain plug
Here's' the clip - Car is out of Virginia (yellow inspection decal in center of front glass)
http://www.motorweek.org/features/go...dlight-upgrade
