928 Forum 1978-1995
Sponsored by: 928 Specialists
Anatomy of a hydro locked engine
Old 05-05-2018, 09:30 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default Anatomy of a hydro locked engine
PO said the engine hydro-locked due to a leaking twin screw supercharger inter-cooler. Sure enough when we pulled the manifold the intake ports were white with dried inter cooler fluid.
Today my son and I stripped the engine. Unless I'm missing something the head gaskets show no indication of failing. No cracked cylinders, but there are some scratches - nothing to bad. Coolant was green no sign of oil.
Here are the pictures of the heads, the block and the inside.
Old 05-05-2018, 09:34 PM
Ducman82
Ducman82's Avatar
i took apart a 4.7 that hydro locked. the cylinder was ballooned out.... and the rod was BENT
Old 05-06-2018, 02:17 AM
FredR
FredR's Avatar
World of difference between an engine that has experienced a coolant leak and one that has been "hydrolocked". Looks as though a good clean of the combustion chambers and a reseal will see that motor back in business
Fortune has favoured the brave on this one!
Old 05-06-2018, 03:05 AM
chart928s4
chart928s4's Avatar
Is there some pitting between the two rightmost cylinders in the first head photo? Seems like that would be something to address if so.
Old 05-06-2018, 10:25 AM
Kevin in Atlanta
The current plan is to have the heads reconditioned and use them for my future stroker project - they have the raised bosses Greg prefers.
I'm going to clean up the short block, pull the pistons get them cleaned reinstall and save it for another project.
Old 05-06-2018, 11:59 AM
Kevin in Atlanta
Yes, there is a very tiny pit where you mentioned. I'll deal with that.
Old 05-06-2018, 04:14 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Call me a pessimist but bores 2,6, and 8 look pretty terrible. How long did it sit?
Old 05-06-2018, 06:22 PM
Kevin in Atlanta
A pretty long time. Based on the insurance card in it - 10 years.
I assumed the bottom end was a loss when I purchased the lot it was a part of. If it isn't that would be a pleasant surprise. All I was hoping for was 89+ heads for my stroker.
Kevin
Old 05-07-2018, 02:24 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,452 Likes on 1,459 Posts
You must have gotten a different set of pictures than I did....
Old 05-07-2018, 05:10 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
FWIW when cleaning the pistons don’t send them out to be hot tanked
i know this process will damage the chromium coating
the best way I have found is to soak the piston in simple green for few hours then scub with a toothbrush then wash in hot water then wash with car soap then spray with wd40 wrap them in a lint free towel and bag till your ready to use them
Old 05-07-2018, 09:07 AM
Kevin in Atlanta
Greg's advice on cleaning is to ultrasonically clean the pistons to remove any oil residue/carbon on the sides and then soda blast the tops.
As mentioned above the whole point of the 89 engine is harvest the heads for a stroker that Greg will build once the dust settles at his shop. So if the block is no good no big loss.
Kevin
Old 05-07-2018, 11:47 AM
davek9
davek9's Avatar
I can confirm that the inter-cooler did and does leak
Old 05-07-2018, 11:54 AM
Kevin in Atlanta
Where were the leaks?
Old 05-07-2018, 12:09 PM
Catorce
Catorce's Avatar
As far as hydraulically locking goes, there are various degrees of it. There is the kind that occurs when the engine is running, which is gives you bent rods, etc.
Sometimes, a fluid leak when the car is at rest fills the cylinders and when you go to crank it, it cranks a bit and then stops solid as if someone removed power to the starter. I had this happen on a 930 with bad CIS injectors that literally filled the cylinders with raw fuel. Cranked and cranked and BOOM, stuck solid.
Pulled plugs, vacuumed out cylinders, all ran fine after injectors were fixed.
Moral of the story: the starter itself is usually not capable of bending things under hydraulic lock.
Old 05-07-2018, 12:22 PM
davek9
davek9's Avatar
The Inter-cooler won't hold pressure, I won't know the exact point of the leak until I get the Inter-cooler out of the lower Intake box and the bottom plate is sealed w/ the "Right Stuff".
Any leak inside that box will get directly sucked into any cylinder that is on the Intake stroke, it's not a per cylinder thing, it's a cooled compressed mass of air that's made available to all cylinders.
I found that the Heat exchanger also leaks, it's now scrap copper, as larger and better ones can be had
Was happy to see that the 2.4 ltr TwinScrew unit itself is clean inside and so far looks to be in great shape, It's all cleaning up well, even the injectors work and some still had old fuel in them when tested
Thanks again Kevin for keeping me in mind !
Dave
Quick Reply: Anatomy of a hydro locked engine
