What is proper operation of electric cooling fans
The amp has a "check" mode for the fans. if one fan goes out it senses that add make the good fan go full tilt. every min or so, the amp "checks" to see if the bad fan will work. you can hear this by the good working fan slow down, it checks, then spins the good fan full bore again if the bad fan does not work.
This may not help this specific problem, but I'm sure many amps, controllers, fans, etc. have been wrongly accused. Total resistance increases throughout the system as contacts oxidize and degrade. The total increase in resistance can reach a point where the amp doesn't "see" the specified narrow range in current or voltage (can't remember which) and will go into "check" mode.
Electron Wrangler
In normal operation: both fans should always be doing the same thing - on or off at the same time and running at the same speed. If they aren't you have a problem.
Alan
Alan
Basic Site Sponsor
Basic Site Sponsor
new information: pretty certain that I have an amplifier that has gone awry. but, it is an intermittent problem and
I believe is heat related. Can a MOSFET (or the amp in general) get too hot, not blow a fuse, but decide to take a nap, only to come
back to life after everything cools down??
Basic Site Sponsor
Basic Site Sponsor
They then overheat, which usually ruins the MOSFIT pretty quickly, but I can imagine it also being intermittent as it heats and cools.
Electron Wrangler
Alan
Chronic Tool Dropper
Popular failure points that lead to these symptoms include connections at the battery. There are two separate feeders from the battery to two separate fuses in the CE panel, then the two circuits continue to the final stages module on the front apron. With the fans runing, you can test for voltage at each fuse via the little openings in the back of the fuse. A needle probe (looks a lot like a paper clip if you don't have a good test-leads kit...) into the openings will help you identify voltage drop upstream of the fuses. Check with fans off. Then connect the fan switch wires at the intake manifold switch to get low fan speed. Hood must be closed or hood switch clinically depressed. Check voltage at the fuses again, compare readings with fans off to find voltage drop evidence. A poor connection in either circuit will appear to be a fan failure to the monitoring system. If one is consistently different, swap the plugs at the individual fans to see if the problem moves with the plug.
Basic Site Sponsor
Basic Site Sponsor
A fan doesn't need to be bad for the amp to think a fan is bad. This checking cycle behavior occurred with my fans. I replaced the fuses. Did not help. Previous owner had swapped the controller (later I did it again). Then with help from Fraggle, swapping amps between our cars...fans still worked in his car, not in mine. Theo then gave me the full education on how the system works, and still, it seemed to be the amp....and Theo sent me an amp he rebuilt. Still, the checking and cycling of the good fan continued. Then a breakthrough. Deoxit in the fuse holder brought almost a year of trouble free operation before the checking behavior returned. I pulled the fuses...and they were melted - not blown. I realized at this point the fuse contacts were acting like resistors, heating up, and reducing current. It becomes a runaway effect - as heat increases resistance. The result is the real damage is in the fuse sockets - ruining the copper fuse holders and melting the fuse block. I decided the fix was replacing the fuse block. The process is described here: https://rennlist.com/forums/928-foru...nor-block.html
All sources of resistance must be repaired, before any tracing of problems can begin. We check all these connections first, whenever there is a fan issue.
Since we have a complete fan system (wiring, fans, logic controller, and fan amplifier) in the shop on a test board, we can take test system over to a car and plug it directly into the car....to check the fans, themselves. (Fan failures are very common, at his point in time.....Mary keeps 4 fans, in stock, at all times.) We can then individually test the controller and the amplifier (which we can do, if these pieces are sent to us.). Saves a whole bunch of money in diagnostic time for our clients.
Amplifier issues are still the most common problem. However, it is important to remember that the amplifiers can fail from the resistance in the actual fans getting too high.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Since it is very difficult to properly test MOSFETs, I have decided to replace them with newer ones. the MOSFETs
are most likely, the culprits. all other components look and test fine. (diodes, connections, etc.) however, there is
a complete absence of any heat conducting paste that I have read should be inside??
is it possible that age and heat have caused the paste to "evaporate?"
could this cause the intermittent overheating that I have experienced?
Basic Site Sponsor
Basic Site Sponsor
