87 Auto dies - erratic tach
That is correct. The new harness connector has number 1,2,3 on one side of the plug. If you insert wires with the numbers on the plug up then it's backwards. Once I removed the terminal ends, flipped to plug over so the notch was up and reinserted the pins the car fired right up with the new CPS.
