Delete the rub strips - best practices for filling holes
Archive Gatekeeper
Jake using TIG >> me using muggy weld, either alloy 1or alloy 5. But theres likely some user error on my part, there...
Basic Site Sponsor
Basic Site Sponsor
i've tried that stuff multiple times on multiple different aluminum "things". They make it look so easy....but I've never been able to get it to work. Makes me feel more retarded than I really am.
I found Muggy Weld alloy 5 a little tricky to work with also, but finally got it figured out. However, my first sentence in my original post in this thread is more generic, and refers to aluminum solder more generally. Some time ago I saw a demonstration at Osh Kosh of low temp aluminum solder and bought some of it. The guy showing it could fill a nickle size hole in the bottom of a pop can with the solder, much like the guy filling the holes in the Muggy Weld video. I also found something similar at our farm and ranch store and bought some of that. It wasn't very expensive. I used one or the other of them to fill some rivet holes in the side of my airplane engine cover. They worked just fine and probably with just a propane torch, but it might have been Mapp Gas.
The aluminum epoxy is a good choice but remember it expands a bit with heat. Make sure you are not using it as “filler”.
When you can’t weld the fender, or even if you do to the back you still need to pop the hole into a crater just a bit to take the fiber glass filler. I have done this twice and both time with proper wait times in the sun, you cannot see the filler in the finished paint.
Some progress. Steel holes are welded. Off to the aluminum welder tomorrow. Painted part need to be buffed.
Aluminum welding completed.
I did think a short while about the side marker delete but wouldn't be right for this car. Perhaps the next. I am thinking about commissioning Hans to make a tool to create a hole for the euro style side marker light when I do that.
They used a piece of aluminum behind the the door to anchor the weld. Here' Ellis Edwards (eestunts.com) a professional stunt man, stunt coordinator and car fabricator doing the clean up on the last weld.
Great guy worked on lots of shows dating back to Baywatch. Had a couple stories about the late Paul Newman and his very brief NASCAR career. :-) Not everybody has a Huey helicopter parked next to their shop.
Before
after before grinding
^^ That is looking great. I have to get rid of my rub strips by replacing the doors and fenders (all due to accident damage from a PO). So much bondo...... Also thinking about deleting the passenger mirror for a true OB look.
Anyways, I hope your paint job looks fantastic after all this effort
Ready for paint...
