Depinning Bosch connectors, and a surprisingly effective el-cheapo tool...
#47
Holy crap Ed, that went beyond pricey and into the retarded territory!! With that price I'm shocked that some high profile Rap Music star isn't wearing a set on a gold chain around his neck!
#48
By the way, the inexpensive pin removal tool set Seth referenced also comes with a round/tubular tool which works great on the barrel connector for the power outside mirrors. It fits perfectly and makes removing those pins a snap!!!
#50
FWIW, I found this thread to check how to depin an injector connector on LR Disco. Despite having the 2 cavities for the tool, implying it had 2 retaining tangs, when I finally got them out there was only one tang present. And it wasnt easy to get the tangs to release!
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
#51
Usually you need to push the depinning tool (I have the same cheap set, plus a few better quality individual tools) very firmly into the connector for the pin to release. When you get it right it practically falls out the plug. I’ve yet to find a connector on the 928 that the cheap set won’t de-pin, ranging from chunky molecules connectors to Bosch AMP junior timer as used on the temp sensors and injectors.
