Need detailed pic of S4/GT/GTS motor
Hi all, I am doing some detailing on my S4 motor and trying to get all the wires nuts and bolts back in the appropriate places. I need some help with the spark plug wires on the right front side as well as the right side hall sensor wire.
I am trying to get a better picture of the spark plug wires mounted to a bracket just to the drivers-right of the dipstick. Is that a three wire or two wire bracket? I see two bolts, which leads me to believe its a three wire bracket but I don't understand which is the third wire. So an additional picture would be appreciated. Also, I'd like to see the routing of the harness for the belt tension and hall sender leads. Do the route behind the bracket for the plug wires? I seem to remember Rob Edwards having some good pics of his motor on a stand. Thanks in advance!
Three wire loom goes behind the dip stick, is bolted to the PS timing belt cover and two wires go in front of the dip stick. That's my memory.
