Festival of Speed at Cal Speedway /Auto Club Speedway April 20 2018 - 928s running?
#136
Wait a second here...
I'm carefully eyeballing the rods, and the shank of MA's rod connects to the small-end at its 4 o'clock and 8 o'clock positions, whereas MK's rod, its shank connects to the small-end at the outside of its 3 o'clock and 9 o'clock positions, MUCH WIDER!
Clearly then, they are different rods where MK's is much wider at the shank where it connects to the small end versus MA's rod.
they both look stout and I have 0 experience in rod design, and also ask the question, how do rods break near the bottom? if i was detonation, wouldn't we hear something on the video? wouldn't that pound out the bearings and cause a failure in the bearings? does it point to a piston failure or a wrist pin failure that would force the piston to gaul the cylinder and then stop..... causing the rod to break and sparing the crank and rod bearings?
Mark anderson and Joe Fan newest rod in failed engine
Mark Kibort stroker engine rod and mark Anderson /Joe fan rod in original engines
#137
Here is the video for RACE 1 of the Porsche Club Festival of Speed at Auto Club speedway.
Greg, I added 3 spots where the rev limiter was tagged , so you could hear the frequency. match it audibly/note-wise to any car on a dyno, on the track and know if it is close to 6600rpm
I starts out with the 1st greed flag lap, with rear view cam, and then a couple of clips of the leaders in some hot cars at the end, and the final lap , with rear cam of a rev limit tag.
#139
The Parts Whisperer
Basic Site Sponsor
Basic Site Sponsor
Apparently, Armchair Einstein's ear needs to be calibrated a bit.....
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#141
Basic Site Sponsor
Basic Site Sponsor
I'm not sure I know how to read this spark plug....unlike any spark plug I've ever seen. I've seen spark plugs with melted center electrodes, caused from excessive timing....but I've never seen anything like this.
The "steel" portion of the plug is bare steel, which looks like something I just removed from my bead blaster. There's absolutely no trace of anything....just bare steel all the way to the base.
It appears like there are tiny "*****" attached to the "strap" portion of the electrode. If you blow up the picture, you can see them.
The porcelain appears to be burned on the left side (in the picture). The rest of the porcelain seems normal.
Comments?
#142
I wanna say a valve stem seal failed causing oil to get into the cylinder, reduce the octane of the gas, and cause detonation.
Seems likely to me as it only discolored half of the spark plug. But this is just my opinion and what I saw with my 81's engine and plugs. Albeit not nearly as severe as this.
Do you have any info on how lean this engine got? It seems to have gotten really hot.
#143
Basic Site Sponsor
Basic Site Sponsor
The hole in the engine is huge....and very wide. The wrist pin is no longer in the piston (the piston is shoved to the top of the cylinder) and the damage is so wide (on the cradle) that I'm already thinking that the pin was still in the connecting rod for quite some time.
Rob Edwards has a great photo of this....maybe he will post it. (Or maybe it is already here?)
Zero recorded data.
#144
Comments?
#145
Chronic Tool Dropper
Plug says detonation. Do you have any pics of the tops of the pistons yet?
#146
Basic Site Sponsor
Basic Site Sponsor
#147
Greg,
I had a plug like that. It was after I'd holed a piston on my Yamaha RD400, ran too lean and melted a hole in the top of the piston. The metal from the piston fused onto the plug.
George
90 S4 Grand Prix White (Murf #5 - 210 mph top speed)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
George
#148
Basic Site Sponsor
Basic Site Sponsor
Greg,
George
George
Very strange!
#149
Greg, you are right on that one! However, what I was suggesting was that the RPM from the video only showed 6600rpm shifts based on audio data.. we both can be right on this one. I thought both joe and mark went back to stock ECU settings.
do you think it was over rev? what do you really think the problem was? he needed the octane of 110, and only was running around 100 and it detonated? doesn't pinging tend to pound out the rod bearings? do you think it could break a rod like this??
#150
What size injectors are fitted? The size specified in the input data array looks suspiciously small considering they are still firing per stoke at 7560 rpm. I suspect my 30lb injectors might be struggling
