I've been bitten by the stroker bug.
#91
I think I have everything except the injectors. 85-86 throttle body mounting points have to be removed from the upper block. Ordered Greg's cam cover elbows from Precision yesterday. Gary will be checking the bearing clearances and providing his custom SBC rod end bearings.
968 head gaskets are on their way from Germany. They'll need to be modified to work on the PS head. It involves cutting and plugging holes to match the coolant flow. Greg has been very generous with his time and guidance. I'd still be in the wilderness without it.
#93
More progress on the stroker parts acquisition front. 968 head gaskets arrived from Germany.
Here's a side by side comparison of 968 anf 928 head gaskets
The 968 PS little work to properly size the coolant passage holes and cut off the rectangular piece sticking out.
The 968 DS needs a lot more work. In addition to the cutting off the rectangular piece, new holes need to be cut out to match the 928 heads and the 968 holes require plugs to be made to block the coolant passages that normally would be blocked by the head gasket.
The making of the head plugs is quite time consuming and tedious work. I am wondering if I could use JB Steel Stick to close the passages.
#94
Why don't you just have cometic make a gasket?
#95
On the advise of Greg Brown this is the direction I'm going.
#96
Crankshaft dirt traps tapped and plugged. Rotating assembly, flywheel have been balanced. Rod end clearances have been checked, rod end bearings are on order.
Next up I guess is balancing the pressure plate, checking main bearing clearances, grooving the 2/6 bearings and assembly of the block (after removing the 85-86 throttle body mounting points)
#97
So, heard from the shop today. The mains clearance is too big. I think he said by 3 thousandths of an inch. They are going to send them out to be coated to make up the difference.
Anybody ever encountered this? My shop confirmed the crankshaft mains are correct and I am using Porsche main bearings.
#98
Åke
#99
Careful measurement is required to determine the oil clearance.
Åke
https://blog.k1technologies.com/how-...ing-clearances
Åke
#101
Most of the parts are ready. Main bearings go out for coating tomorrow. Once they're back Gary will build a custom fixture to hold the 2/6 bearing while we removes the material.
Gary Grimes, the owner, explains that getting to a tighter clearance nearer 2.5 thousandths will improve oil pressure.
Also, he almost exclusively uses Cometic head gaskets and has never had a failure. He pulled one for me to see. Greg, his machinist, added that he uses a copper spray to coat the Cometic head gaskets and that eliminates the failures.
Block with S3 bosses removed
Balanced flywheel and pressure plate with instructions
Carrillo rods post main bearing clearance check
SBC rod bearings
Have the balanced crank, too. The plugs left loose for final cleaning
1/8" threaded dirt trap plugs left loose for final cleaning
Plug for balance
SBC rod bearings
Plug for balance
#102
Correct 104mm ring gap
Is this the correct information for the 104mm ring gaps for my stroker?
#103
Basic Site Sponsor
Basic Site Sponsor
I've yet to install a Cometic gasket that did not seep between the layers. Butt smooth surfaces, slightly rougher surfaces, no difference. Not one or two....but every single one I've ever installed seeped. Although I found that I could pour in a can of Stop Leak to "cure" the problem or I could "spray" the gasket (against their recommendations) with sealant between the layers to "cure: the problem. It just seemed like I should not have to do this, to male their product work.
I finally just gave up.
It's so chronic for me, that I finally decided that Cometic's "parent company" must be Rainbird.
There's two other reasons:
1. I like the head gasket to be the "fuse" in the system, should anything go wrong. Stock style gaskets are like putting a 25 amp fuse into a 20 amp load.....they are the perfect match for the surrounding pieces. Cometic gaskets are like putting a 50 amp fuse in a 20 amp load.....something else is going to "melt' before they do.
2. I've got a lot of experience looking at stock head gaskets (don't forget I've got a bunch of 951 experience). I can "read" stock head gaskets. "They "talk" to me.".
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#104
Basic Site Sponsor
Basic Site Sponsor
#105
