I've been bitten by the stroker bug.
#76
Basic Site Sponsor
Basic Site Sponsor
Progress is being made. While the '89 heads are out being cleaned and getting PAC springs and retainers, Ferrea locating disks I am gathering up more goodies.
I have most of a pan spacer kit from a local owner.
Today I got the matching oil pick up for my early oil pan pictured here:
Should I extend the pickup the way 928 Motorsports does theirs?
And your rods are being shipped, to me, from Carrillo!
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#77
Basic Site Sponsor
Basic Site Sponsor
I'll reword.
Kevin:
My design bolts on and lowers the entire pick-up. About $40 for all the pieces and hardware, including a new factory pick-up seal.
I have no idea of what Carl is doing or what it costs. You should compare....might be cheaper, with the same result.
#80
Valid point.
I'll reword.
Kevin:
I'll reword.
Kevin:
#81
Developer
Thanks, Greg.
I didn't like the idea of spacers between the pickup and the block (more failure points, any leak in the suction pickup will suck air and end or reduce the oil flow, or entrain air bubbles into the oil).
So that's what we didn't go the spacer route.
We take the stock oil pickup, section it, add a slip-collar of the right diameter, and TIG-weld it back together. That's how we lengthen them.
Worth noting: I do not know the thickness of Greg's oil Pan Spacer. Ours is a full 3/8". Where this becomes important is if you were to use our 3/8" extended oil pickup with a shorter spacer, it might not work. I recommend you get the extended oil pickup that matches the length of the oil pan spacer.
Here's a pic:
Showing our extended reach oil pickup tube for 928s equipped with 3/8" oil pan spacers.
Here's a pic:
#82
Basic Site Sponsor
Basic Site Sponsor
Thanks, Greg.
Here's a pic:
Here's a pic:
The spacers are sandwiched between the pick-up and the block...in the same mounting holes as stock. The odds of them coming loose are exactly the same as the stock pick-up coming loose....the hardware needs to fall out. I've never seen this happen, on a stock pick-up.
In terms of leakage, the only leakage on a pick-up system that I've seen has been using an "aftermarket" pick'up seal, which is why I furnish a factory pick-up seal, with my pieces.
Serious question....not trying to create anything...purely interested in what you think:
Porsche made that large "cup" just above the screen, for some reason. On an "early" oil pick-up system, this same "cup" isn't on the pick-up, but is on the bottom plastic "cloverleaf" piece.
I've always thought that the tall "cup" acts as an anti-slosh device, placed in the middle of that large reservior. The tall walls "block" oil from sloshing all they way from side to side or front to back of the oil pan.
I do suspect that it's not there because they had some "extra" plastic (early) or steel (late) sitting around and decided to add that "cup", but it serves some sort of function.
Since you radically modify (shorten) those walls to do your pick-up modification, you obviously gave this some thought. What do you think the function of that added height was....and what is changed when you remove it?
#83
Somewhat related, does this require a longer dipstick?
#84
Archive Gatekeeper
I'd you want it to read correctly, yes.IIRC Carl has a long dipstick replacement.
#85
Developer
We sell our dipsticks in two lengths: https://928motorsports.com/parts/improved_dipstick.php
...to cover those that have oil pan spacers.
#86
While I wait for Greg to ship my rods, oil pan spacer kit and ATI Super Damper I need to get a head gasket set for the stroker.
What are my options for 104mm head gaskets?
Kevin
Kevin
#88
Deleted.
#89
Everything assembled to start the build. Gary will balance the assembly, pressure plate, flywheel and super damper. And he will be milling the groove in the 2-6 bearing, too!
