Intake and Cam Cover Refresh questions
#121
Received 1,543 Likes
Seth and Dave - Super helpful responses...
Dave - I think what you see is all there is. Reversing the bend in the boot so I could have access to pick out the bits of male connector split the boot, then split the wire insulation on the two wires. There are no other locations where wires are exposed.
I like Seth's idea to use heat shrink on individual wires, then one larger heat shrink over all three wires.
I did notice it looks like the shielding is kind of pony tailed into that top connection.
See below for an example. This is a random interwebs image of shielded wire, not the CPS branch.
#122
Dave, sorry about that. Yes, I depinned the connectors because I was installing all new connectors. I was not terribly impressed with the quality of the new Bosch metal terminals, so I depinned to keep the OEM terminals rather than cut them off. Granted, it was a bit of a b*tch releasing the terminals. Go figure that last month I bought an el-cheapo terminal release set off ebay that fit PERFECTLY.
Jon, I would not approach this without considering depinning the connectors for repair.
I second what Dave said about shielded wiring. It gets hairy quick terminating that.
Good Luck!
Good Luck!
#123
Seth,
Did you document how you depinned the connectors? I'm thinking of "surgically" (Dremel) cutting up the old connector to release the pins from the connector without removing pins from wires. I'm hoping that with the pins free I can slip heat shrink over them and down over the split insulation on individual wires, then one larger piece of shrink over all of them, put on a new boot, insert pins into new connector, pull the boot up. The main goal being to not actually take any of the wiring connections apart. Of course what I'm suggesting could bare no resemblance to how things are put together. Some details on how you did it would really help. The shielding connection is the one I just don't want to mess with.
Thanks!
Thanks!
#125
On a Lighter Note...
Thank You Seth! Excellent guide.
My intake is finished. Got these pics from the powder coater.
Details:
- Prismatic Powders "Porsche Silver" (matches the fine flake silver used by Porsche)
- Primer, base color, then cleared
Details:
#127
Painted the cam cover umbrella washers with VHT Engine Enamel paint
I like the look of fresh Cadmium....but it's whole purpose is to sacrifice itself and corrode. I considered gold paints, including VHT, but none were a convincing Cadmium look alike. I decided to not even try to match and come up with something that would be tasteful. I followed the directions on the cans. Used the timer on my phone to make sure I got the coats on properly. Primer, Paint, then Clear. Baked in the oven this afternoon at 200F for an hour. It looks good. The color is "cast iron" but it really looks kinda like anthracite (which I expected it would if cleared).
#128
Picked up the intake parts from the PC shop
Nice of them to wrap them. They look even better than photos can reveal. The clear coat adds depth that isn't captured in photos.
Even nicer of them to remove all the flaking paint from inside. Bare metal. The guy who did it explained how they cleaned it. I can't find any residue anywhere. He said "Wash it if it will make you feel better". They baked/degassed the parts three times. There is no oil remaining inside...nothing sticky to hold media.
#129
Dismantling the throttle body flappy mechanism
I decided to replace the bearings. I found the springs, lever arms, and assorted washers a bit different on my "88 than what Dwayne shows was on his "87. I managed to keep the black plastic "spool" in one piece (so far). A bit of s struggle to getting the small circlip on the TPS side out, even with small circlip pliers. I was careful due to Dwayne describing how easily it bends past it's elastic limit...and luckily I didn't exceed it.
#131
The PC looks beautiful. Maybe I missed it but who did you use? Your teaser really begs the question: What was the stripping/cleaning process as he explained it? I will be refinishing shortly and am compiling best practices. Thanks for a lot of new twists on a much-documented job.
#134
EDIT: The great results shown above lasted 3-4 weeks. By 4-5 weeks the clear coat on the intake looked like finely shattered glass. See later posts with pictures. Cause of failure: insufficient curing time. Likely due to the internal temperature of the intake lagging behind the surface temperature.
Last edited by Captain_Slow; 06-21-2018 at 11:04 AM. Reason: Shop didn't cure the clear coat properly.
#135
