Fuel damper leak (front)
Hi, I have just completed the intake refresh on my 86.5 following Scott's detailed post (thanks Scott it was terrific). Anyway everything tested well with the exception of a fuel leak in the fuel damper at the front of the engine. The fuel lines aren't leaking so I assume there must be a faulty diaphragm. Any advice on how to diagnose it further? Thanks.
Team Owner
spray PB blaster on the B nuts,
get a 15 mm and 19mm wrench and remove the lines,
then remove the 24mm nut holding the damper and replace it.
NOTE once a damper is leaking its best to replace all of them, both dampers and the FPR.
NOTE if the fuel lines are original its time to replace all of them in the engine bay
Chronic Tool Dropper
