928 Forum 1978-1995
Sponsored by: 928 Specialists
Stripped bolt problem
Old Feb 17, 2018 | 07:24 AM
StratfordShark's Avatar
StratfordShark
Default Stripped bolt problem
This should be so simple but having no success so far.
I was replacing hood release cable, and to route it through had to remove the top radiator rubber 'bumper' hold down on the RHS (mine is RHD). The bolt is 6mm Allen, and in removing it I noticed the hex was very worn, so replaced it with a nice new high quality bolt. I'd replaced the rad a few years ago, but kept the nice cad plated bolts there for originality's sake.
So I thought it sensible to replace the LHS bolt also, but it stripped out when I tried to remove. Since then I've cut slot in head and tried to get it moving using screwdriver as chisel, but it won't budge. The hole is too big for a T40 torx, but you can't get a T45 in there. Neither can you hammer in a 1/4" hex bit which is 6.35mm. I can't get one of my trusty Irwin bolt grips onto the head, as it sit's in a recess with cutout in lip of fender. For same reason it won't be possible to weld a nut onto the head as that lip gets in the way. Vise grips on the headd just slip. I have various screw extractors, but since the bolt won't budge when I try to persuade it with hammer and screwdriver, I can't see it moving. I'm going to try an impact driver with the original 6mm bit, and see if that shocks it into moving.
Any ideas what else I should try? I thought I knew all the stripped bolt tricks by now, but this one is defying me. Yes I could just leave it in, but it's going to haver to come out some day and now it's getting personal!
Old Feb 17, 2018 | 07:49 AM
beran earms's Avatar
beran earms
It doesn't look wet with any penetrating oil, maybe that could help some. No way to weld to it ?
Old Feb 17, 2018 | 07:59 AM
StratfordShark
Thanks I have tried lots of penetrating oil on earlier sessions, but getting any into the threads under that washer and bracket is probably why that was no help either.
Will try welding with precaution of disconnecting battery, brains and check I can get a good ground nearby. Maybe a small nut will fit and leave room for socket.
Old Feb 17, 2018 | 08:30 AM
Adk46's Avatar
Adk46
Just yesterday I used the cold chisel method on a torque converter housing bolt. I may have had better access than you. I hammered in it in straight to get it started then veered off to encourage it to turn. I sheared off chunks of it but it wouldn't twist. I had not yet fully stripped the Allen socket, so gave one last try - and it came out. The chisel probably broke the friction under the head, leaving only the threads.
Old Feb 17, 2018 | 10:06 AM
FredR's Avatar
FredR
The impact driver is the first stop for you- just use a great big lump hammer for the percussion- that often works wonders. If that or other devious tricks fail next step is to remove the head of the bolt then you can get the securing bracket off. That should leave you short stub to play with that you can try some releasing fluid on. Beyond that you can also try to drill the bolt out
Old Feb 17, 2018 | 10:44 AM
SeanR's Avatar
SeanR
Drill the head off of it. Be careful on the amount of force you are using on that tab, it comes off the body easier than it should.
Old Feb 17, 2018 | 10:45 AM
Chris Lockhart's Avatar
Chris Lockhart
Drill the head off. Then if the shank is actually frozen in, step drill it up carefully (keeping it centered) to just under the thread size. Then pick the pieces out with a pic. Good luck with it.
Old Feb 17, 2018 | 10:47 AM
Chris Lockhart
LOL. You beat me to the punch Sean.
Old Feb 17, 2018 | 11:02 AM
V2Rocket's Avatar
V2Rocket
Rainman
one more step to try before drilling is getting a spare XZN (cheesehead, triplesquare) bit and hammering it in there.
most of the time the splines will dig into the allen head well enough to crack it loose.
if you have a nice set of bits you dont want to sacrifice you can use a cheap set from auto store, about $8.
Old Feb 17, 2018 | 11:26 AM
StratfordShark
Thanks all, lots of ideas there.
The impact driver with 6mm but didn’t work, but it doesn’t help that head isn’t exactly a precision fit now!
I’ve ordered cheap set of spline/triple square so I can try that before resorting to drill. Very puzzling - not as if it’s a highly torqued bolt. At least it’s not holding me up - just nice to fix correctly.
Old Feb 17, 2018 | 12:22 PM
SRaouf's Avatar
SRaouf
One more thing before you destroy it. Try zapping it a few times with a Mig welder if you have one. Sometimes the burst of heat has the same effect as an impact driver.
Old Feb 17, 2018 | 12:25 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Think about where the other end of that bolt is. Is it accessible after removing the wheelhouse liner? Maybe you could get some penetrating fluid up into the threads from that end.
On my car, these and the crossbrace bolts appear to be zinc plated rather than cad. I'm not sure why, but it came up as I was cataloging fastener finishes in the engine bay for posteriority.
Old Feb 17, 2018 | 12:42 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Old Feb 17, 2018 | 01:42 PM
StratfordShark
Thats a good idea. I have MIG, any bolts I’m working on are red hot in an instant so would blow any corrosion away. But I couldn’t apply welder tip without dropping weld into head, so may as well try welding but on, or am I missing something obvious?
Old Feb 17, 2018 | 03:33 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
once that bolt gets hot it will come free,
if you had an induction heater to heat the bolt head then use the chisel.
I like the airhammer /chisel for best effect,
heat the bolt first
