928 Forum 1978-1995
Sponsored by: 928 Specialists
Wrench designed with our car in mind
Old 02-13-2018, 09:45 AM
Andre The Giant
Andre The Giant's Avatar
Default Wrench designed with our car in mind
https://www.homedepot.ca/en/home/p.1...000769949.html
  • Shark fin design, heavy duty, carbon steel
Old 02-13-2018, 12:13 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
But it's not metric...
Old 02-13-2018, 12:28 PM
GT6ixer
GT6ixer's Avatar
Good for yankin' relays out...
Old 02-13-2018, 05:16 PM
monkez
monkez's Avatar
To be honest, i bought a tite-reach hoping that it would work to help get to bolts where my sausage fingers (and accompanying knuckles), can't get to. It works remarkably well and their low profile sockets also came in handy. http://www.tite-reach.com/
Still needed my daughter's hands to feed a few bolts on the oil pan though, especially the one on the front driver's side corner. that one is a bastard
-adam
Old 02-13-2018, 07:30 PM
dr bob
dr bob's Avatar
That tight-reach looks handy. The shallow sockets are the trick part of this, and would be handy on their own. Great for the bolthead end of fasteners, not so good for nuts.
For the oil sump bolts a GearWrench is good right up to the point where you want to put exact torque on those hard-to-access bolts. Then you'd want to use the tite-reach tool.
Good Stuff!
Old 02-13-2018, 09:03 PM
Wisconsin Joe
Wisconsin Joe's Avatar
All of my "crescent" type adjustable wrenches have an 'inch' scale (and the length in inches) on one side, and a metric scale on the other.
The scale is along the jaws, showing how far they are open.
The pic in the link shows the inch scale on one side, but doesn't show the other side.
Old 02-13-2018, 09:15 PM
monkez
monkez's Avatar
Dr. Bob, you're right about the shallow sockets, but that tite-reach really allows for better leverage when trying to break loose a bolt. I'm not getting a commission or anything, but it really helped that much. Especially on certain hard reach bolts on the cross member and the headers.
Old 02-14-2018, 12:35 AM
jorj7
jorj7's Avatar
It's the same with this one:
Looks like the the 10" crescent (250 mm on the back) cab go to 35mm...
George
90 S4 Grand Prix White (Murf #5 - 210 mph top speed)
94 GTS 5-Speed Midnight Blue
06 Cayenne S Havanna/Sand Beige (PASM)
http://928.jorj7.com
Old 02-14-2018, 12:37 AM
dr bob
dr bob's Avatar
By my estimation then, it will tighten SAE fasteners, and loosen metrics? Maybe I'm not seeing the value yet. Is there one with the little vernier scales flipped the other way? Then the pair of wrenches could serve any modern car.
Old 02-14-2018, 02:11 AM
skpyle
skpyle's Avatar
boo, hiss...
dr bob, that is terrible. And only for people who follow the directional arrows at the base of the adjustable wrench.
Old 02-14-2018, 09:40 AM
Andre The Giant
I only posted it because it said shark fin design ! The reason i need one of these in my arsenal is to hold the shock shaft from turning while I try to loosen the top bolt of the shocks which hold it to the coil springs.
Quick Reply: Wrench designed with our car in mind
